Hotpoint WMA46 Front Load Washer Logo
Question about Hotpoint WMA46 Front Load Washer
Does not empty at end of wash cycle (not blocked or pump)
Machine goes through wash cycle normally but then it does not empty at the end of the wash cycle and three lights come on, wash, rinse & spin & final spin (ignoring door locked light obviously). It does rinse and spin if put on this program manually so is not blocked or dead pump). Any ideas please?
Posted by hoppernic on
Bill Boyd
    Top Expert:
  • Hotpoint Master
  • 53,816 Answers
Faulty program board not progressing
call a technician
Posted on Jan 01, 2018
2 Related Answers
Anonymous
  • 903 Answers
SOURCE: WMA46
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Posted on Oct 23, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: the water wont drain from my machine from the wash
What you need to do is check the pump is getting a feed to it
Select a spin cycle, and with a test meter, test for voltage across the pump terminals, if you are getting a feed, and the pump is working ok, then you obviously have a blockage beyond the pump.
If no voltage then could be a broken wire, or a faulty programmer/board.
ONLY CHECK FOR VOLTAGE IF YOU ARE COMPETENT TO DO SO, as it takes no prisoners.
Hope this helps.
Posted on Dec 07, 2009
Hi there Washing Machine model: WFA0877A My wash cycle was abruptly ended and all three indicator lights are switched on. How do I resolve this?
http://www.manualsdrive.com/results.php?lang=en&search=BRANDT%20WFA0877A#.VIhIUXtwnBQ
send your email get the user manual
all three lights on is blocked up drain
the pump not rotating {check for wires and coins}
i would empty the machine fully at the drain cycle and also at the pump filter
till its all empty
switch off and remove the water pipes and the mains plug
then pull out and lay the machine over on the side
opposite the soap drawer
then underneath you will see the pipe that goes from the drum
to the pump
take it off both ends and check its totally clear and any trap {a ball and also sometimes in a cage}
shine a light inside the drums and look around for socks or tights or plastic etc {have kids check for lego plastic toys etc etc }
clothing wires in the pump end
and check the drain
make sure the drain at the waste end is clean and flows well at the sink etc...
put it all back together
and try to hold in the program select or start stop button for a few seconds when you apply mains
then this resets the fault it detected
it should work aok
if not what part of the cycle did or does it stop at???
this will give more info that the three stuck lights
i can see the manual online for it
perhaps it has some details
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Washing machine will not empty water on spin cycle?
Usually the pump goes bad on a washer first. I would check the drain hose and make sure it is all clear before you replace the pump. But I would be 95% sure its the pump. Please rate my answer so I am rewarded points for it.
5helpful
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
My washing machine spins at end of its cycle, however, the clothes are still soaking wet. Will it be that the pump has gone as I've emptied the filter
most likely the pump is blocked......................small coins easily block em......
did 1 last monday and the pump had a penny pluss a wire from a womans bra..........
just clear the pump and job done.......
see if you can get machine near an open door first .....
let rear hose lay outside,...
it will help get some of the water away............
cheers
5helpful
Hotpoint WT640 - it's flashing f-05. I emptied the machine and put on another wash and it says the same thing halfway through the cycle?
F-05 normally relates to the pressure switch,which normally points to a blockage.Does the machine empty slowly if so I would check the drain pipe first and if that is ok then you need to look down at the drain pump which may have a blockage in the filter which is inside the sump pipe,this is the main hose from the base of the drum and goes to the pump.
Hope this helps.
1helpful
2answers
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
