20 Most Recent Brother Reset Gear for TN-450 TN450 TN420 TN-420 Toner Cartridge HL-2230 HL-2240 HL-2240D HL-2270 - 6800 Page Yield Questions & Answers
Hl 2270 won't stop printing
I would guess you were trying to print a spread sheet or similar. It has nothing to do with the reset gear on the cartridge. You need to open your printers folder on the computer, open the print queue for the printer, and cancel all documents waiting to be printed. That may take more than one try. When you are ready to print again, be sure you know what is to be printed before committing.
9/21/2014 11:40:43 PM • Brother Reset... • Answered on Sep 21, 2014
Como deshabilito el informe de impresion de brother mfc-j1010dw
Question edited and translated to English. We are a North American website, we only speak English. You can't https://www.google.com/search?q=Brother+MFC-J1010DW+%22disable%22+print+report ..
3/23/2024 1:39:34 AM • Brother Office... • Answered on Mar 23, 2024
Brother MFC-J985DW Colour Inkjet Multifunction Printer. Why doesn't the paper jam message go away?
Question edited for clarity. 985 or 895? Usually because the jam hasn't been cleared or the machine hasn't been reset. Remove the paper tray an open the cartridge bay. Open the rear paper door, check underneath. This machine has a lot of paper scraps in it. :>D
3/17/2024 12:10:58 AM • Brother Office... • Answered on Mar 17, 2024
How Do I Fix Brother Scanner Error Code 2023?
https://help.brother-usa.com/app/answers/detail/a_id/74629/~/error-2023---usb-communication-error "Error 2023 - USB Communication Error" This typically indicates a communication error between the Brother machine and the computer. 1. Turn off the Brother machine, wait 15 seconds and then turn the machine back on. 2. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, go to step 3. Warranty Calculator to check the status of your machine's warranty. If your machine is out of warranty, we offer a repair option. Please contact Customer Service for warranty or repair options. - If the USB port appears undamaged, go to step 5. step 8. here for instructions. 9. Download and reinstall the Scanner driver, which includes the DSmobileCapture software. Click here for instructions. Don't reinstall using the DVD. Instead download the latest version of the software from http://support.brother.com. 10. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, then the issue is likely caused by a software conflict. If you have another computer, try installing your machine on that computer and scanning. This will determine if there is a problem with this computer. If after troubleshooting you are still unable to scan, contact your computer manufacturer for additional support.
2/20/2024 2:59:01 AM • Brother Office... • Answered on Feb 20, 2024
What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue: Check for a dial tone: 1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone. If there is no dial tone, press Hook again and proceed to step 2. If there is a dial tone, press Hook again and move to step 4. 2. Verify telephone cord/line connection: Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side). If the cord is already in the LINE port, proceed to step 3. If it's connected to EXT, remove it from there and connect it to the LINE port. Press Hook and check for a dial tone. If still no dial tone, proceed to step 3. If there's a dial tone now, move to step 4. 3. Test with a known working telephone: Disconnect the telephone cord/line from the LINE port on your machine. Connect it to a known working telephone and test for a dial tone. If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider. If there's a dial tone, reconnect the cord/line to the LINE port on your machine. Press Hook and check for a dial tone. If still no dial tone, consider warranty and service options. If there's a dial tone, proceed to step 4. 4. Remove splitters or other devices: Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack. If yes, remove them for testing purposes. After removing any devices, continue to step 5. 5. Adjust Compatibility settings: Press Menu/Set. Navigate to Miscellaneous > Compatibility. Choose Basic (for VoIP). Press Menu/Set and then Stop/Exit. 6. Send a fax: Insert the document face down in the Automatic Document Feeder (ADF). Adjust paper guides to fit the width of your document. Enter the fax number using the dial pad. Press Fax Start. Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance. If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider: Epson WorkForce WF-2750DWF: This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen. Features: Print, copy, scan, and fax. Scan resolution: 1200 x 2400 dpi. Dimensions: 16.73 x 14.17 x 9.06 inches. Weight: 14.55 lb. It's a budget-friendly choice for home and office use. Brother MFC-L6800DWT: A high-speed monochrome laser fax machine with additional features like printing and scanning. Ideal for small offices. Check out its performance and ease of setup. Canon TR8620: A multifunctional all-in-one printer, copier, and fax machine. Offers versatility and functionality for various tasks. Consider it if you need a reliable fax solution
2/15/2024 2:09:59 AM • Brother Office... • Answered on Feb 15, 2024
Brother HL-L2340DW toner reset counter had brother HL-2040D and was able to reset toner counter
1-877-BROTHER (877-276-8437) M-F, 9:00am to 9:00pm Eastern Time
1/17/2024 5:05:45 AM • Brother Office... • Answered on Jan 17, 2024
2answers
Repair a Brother Printer MFC 235C
Depends what is wrong with it.
1/8/2024 2:00:28 PM • Brother Office... • Answered on Jan 08, 2024
Brother ML 100 typewriter. When I type it does different things like symbol or numbers and barely ever prints a letter and if it does its not the same letter that I pressed.
Question edited for clarity and typo. Contact Brother Support for a warranty claim or the address of a Service Centre. Someone is selling a new one for $600! It is a Daisy Wheel printer, so make sure the wheel is located correctly. https://www.google.com/search?q=Brother+ml+100+typewriter ..
12/20/2023 9:32:46 PM • Brother Office... • Answered on Dec 20, 2023
2answers
Factory reset Brother MFC-7320
1. Open cartridge cover
2. Press the button Clear / Back
3. Press start button
4. Print number 11
5. Close cartridge cover
Now, your printer is returned to the factory settings.
10/12/2023 4:41:30 PM • Brother Office... • Answered on Oct 12, 2023
Fuser changed now it Do nit work it means
What I understand, you changed the fuse and after changing the fuse, printer is turning ON? If so did you checked the fuse again? If it is blown again then there is a fault in Power Supply Section. For further reading, visit page no: 142 of part 6 of manual (Troubleshooting) cv_hl3040cn_usaeng_usr_0.pdf (brother.com)
10/11/2023 1:12:02 PM • Brother Office... • Answered on Oct 11, 2023
2answers
How do I down load Drivers for Brother MFC 8500 for Windows 10 pro 64bit? Buit in drivers in MS Win 10 does not work
Directly from the Brother web site. https://support.brother.com/g/b/downloadtop.aspx?c=us_ot&lang=en&prod=mfc8500_us
9/24/2023 9:04:45 AM • Brother Office... • Answered on Sep 24, 2023
How do I find the - symbol on my brother printer?
To type symbols,
  1. Press the [Symbol] key ( / ) to enter the Symbol selection screen.
  2. Press orto select the desired category.
  3. Press the [OK] key ( ) or [Enter] key ( / ).
  4. Press , ,or until the desired symbol appears.
  5. Press the [OK] key ( ) or [Enter] key ( / ) to add the symbol to the text.
https://support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=d450euk&faqid=faqp00000856_035
9/1/2023 2:58:07 PM • Brother Office... • Answered on Sep 01, 2023
Brother printer ink cartridge chips
Unlike the inferior Epson cartridges, the Brother printer resets the chip when you refill them. Follow the installation of fresh cartridge instructions.
8/19/2023 5:04:31 PM • Brother Office... • Answered on Aug 19, 2023
Brother MFC-j835DW. Where is the ink absorber on it please?
MFC-J835DW - Ink Absorber Full - Brother support
Brother USA https://support.brother.com > faqend > prod=mfcj835... Jan 20, 2020 - The ink absorber box or flushing box needs to be replaced. > Contact Brother customer service from the "Contact Us" section.
How to the reset ink absorber full error on a Brother ...
Printer Bullet https://www.printerbullet.com > blog > How to the res... With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable). Hold down MENU/ ... ..videos. They all run to the same theme.
8/1/2023 5:14:29 PM • Brother Office... • Answered on Aug 01, 2023
Brother printer/scanner MFC-J485DW scanner bar can't find home position
The is a lot of help and videos in the bottom link, but this post appears to fix the issue according to Brother, and the link below that from iFixit gives an alternative solution but way more complicated..
"Unable to Init. AF"
Brother-USA https://help.brother-usa.com > answers > detail > a_id The message "Unable to Init. AF" will appear on the display for one of the following reasons: i. A foreign object, such as a paper clip or ripped piece of ... Videos https://www.ifixit.com/Answers/View/332612/Brother+MFC-J825DW+Printer+%22Unable+to+Init+AF%22+Error+Code https://www.google.com/search?q=Unable+to+Init.+AF ..
7/14/2023 12:09:02 PM • Brother Office... • Answered on Jul 14, 2023
Have brother dcp l2540dw laser printer will print from computer but will not make copies pl help
Could the DCP-L2540DW be waiting for another page to be scanned for a two-sided document? If it is set for manually copying both sides of a page that is on the scanner glass, press 2 or the down arrow to get the copy to print. See the basic user guide available here: https://support.brother.com/g/b/manualtop.aspx?c=us&lang=en&prod=dcpl2540dw_us_as to find the section to set the copy function to turn off the two-sided option. If the LCD screen says "out of memory", you need to get faxes and other print jobs out of memory or turn off memory receive. If the LCD screen shows "scan unable", then the scanner mechanism may not be moving properly. Try turning the all-in-one off and unplugging it for a while. If the mechanism is still stuck when the power is connected again, then the unit needs to be repaired or replaced. If it is under warranty (1 year unless you bought the extended protection), contact Brother. Cindy Wells
7/10/2023 10:57:44 PM • Brother Office... • Answered on Jul 10, 2023
2answers
Brother 8510 Faded image ?
If you have replaced multiple components in your Brother 8510 printer, including the oven unit, laser unit, high voltage board, power board, and drum unit, but are still experiencing faded images, there are a few other potential causes and solutions to consider: 1. Toner Cartridge: Ensure that you are using a genuine and compatible toner cartridge for your Brother 8510. Low-quality or incompatible toner cartridges can result in poor print quality. Try replacing the toner cartridge with a new, genuine Brother cartridge to see if it resolves the issue. 2. Toner Density Settings: Check the toner density settings in the printer's software or control panel. If the density is set too low, it can result in faded or light printouts. Increase the toner density setting to see if it improves the print quality. 3. Cleaning the Corona Wire: The corona wire is responsible for transferring the toner to the paper. If it is dirty or contaminated, it can cause faded prints. Consult your printer's manual for instructions on how to clean the corona wire properly. Be careful when handling the corona wire as it is delicate. 4. Print Settings: Check the print settings on your computer or within the printer's software. Ensure that you are using the appropriate print quality settings and that any power-saving modes are disabled. Adjusting the print settings to a higher quality mode can enhance the print quality. 5. Contact Brother Support: If you have exhausted all the troubleshooting steps and the issue persists, it may be beneficial to reach out to Brother customer support or a qualified printer technician. They can provide further guidance or arrange for a professional inspection and repair of your printer. Remember to follow the manufacturer's guidelines and safety precautions when working with printers and their components.
6/27/2023 4:05:35 PM • Brother Office... • Answered on Jun 27, 2023
Brother HL3170CDW printer. Waste Toner Box clearing error message.
There is a section at the end of this post https://www.fixya.com/support/t23105023-reset_waste_toner_in_brother
  1. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
https://www.google.com/search?q=Brother+HL3170CDW+%22install+waster+toner+box%22++clear+error+message ..
5/9/2023 4:14:21 AM • Brother Office... • Answered on May 09, 2023
Brother Reset Gear for TN-450 TN450 TN420 TN-420 Toner Cartridge HL-2230 HL-2240 HL-2240D HL-2270 - 6800 Page Yield Logo
1 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
hl 2270 stop printing
  • Office Equipment & Supplies
