20 Most Recent
OKIPAGE 8W Led Printer Questions & Answers
Oki microline 280 eco jumps around .75" for each new page
There could be a few possible reasons why your Okidata Microline 280 Eco printer is jumping around 0.75" for each new page. Here are some things to check:
- Check the paper feed mechanism: Make sure the paper is feeding correctly through the printer and that the paper guide is properly aligned. If the paper is not being fed correctly, it can cause the printer to jump around.
- Check the tractor feed mechanism: The tractor feed mechanism may not be gripping the paper correctly, causing it to feed inconsistently. Make sure the tractor feed mechanism is properly aligned and tightened.
- Check the page length settings: Double-check that the page length settings are correct and that they match the size of the paper you are using. If the settings are incorrect, the printer may not be able to print the entire page and may skip to the next page prematurely.
- Check the top of form settings: Make sure the top of form is set correctly and is not too close to the top of the page. If it is too close, it may cause the printer to jump around.
- Check the print head alignment: If the print head is not aligned correctly, it can cause the printer to jump around. Check the print head alignment and adjust it if necessary.
If none of these steps resolve the issue, it may be a hardware problem with the printer itself. In that case, you may need to contact Okidata technical support for further assistance or consider taking the printer to a professional repair shop.
What is 811 error?
You cannot repair this error easily. Most times its the main board that has the problem but its more than likely to be the scanner pcb than the main board. I am actually in the middle of the very same error and have tried the main board and it is the scanner pcb that is causing this particular problem. As you do not state what model you have , I cannot give you a part number.
How to solve oki error code 994
I believe that this is a high-temperature error. so, you might need to move the printer to a cooler room or lower the temperature of the room that the printer is in.
Thank you.
OKI MC352 Paper Jam 380 constantly
Unplug the machine. Pull the machine out. Remove all the paper trays. Open all the doors. Remove the Toner. Get a flashlight and look for a small piece of torn paper from a previous jam that was torn when pulled out. Clean the rubber feed rollers with a damp soapy cloth, rinse and leave to dry. Reassemble the machine. Put in new paper from an unopened pack as paper can get damp this time of year. Reconnect power. Try again.
https://www.google.com/search?q=OKI+MC352+paper+jam
Como puedo corregir el error 990 de la impresora oki 330dn
RESET OKIDATA TONER DRUM
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100\%.
