Question about OKI Office Equipment & Supplies
Sounds like the printer heads needs to be clean or a paper jam.
your printer should have came with self cleaning software
paper jam
remove paper tray, open all access to printer to check if there is a crumbled paper or even a small torn piece of paper from a previous jam.
if successful restart your printer
Posted on Aug 23, 2019
SOURCE: Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Posted on Sep 26, 2007
SOURCE: OKI PRINTER B4250
You have accidentally pulled the back paper tray. Even when pulled a little, this tray tells the printer to deliver output to the back. This is useful when printing on heavy, or thick paper. Just push it back all the way down to it's original place.
SOURCE: Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Posted on Dec 24, 2007
SOURCE: My oki c3400 printer makes a really loud clicking
My OKI C3300 was the same and an engineer found the Cyan drum was bouncing on its gears being very stiff to turn. We changed the drum but it was still the same. Changing the cartridge cured the problem, that was jamming the drum.
Posted on Apr 22, 2010
SOURCE: Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Posted on Jun 08, 2010
Nov 09, 2016 | OKI Office Equipment & Supplies
Nov 29, 2013 | OKI C3400n Laser Printer
Jan 04, 2011 | Office Equipment & Supplies
Nov 21, 2010 | Samsung ML1650 Printer
Oct 24, 2009 | OKI C5500n Printer
Mar 11, 2009 | Canon Office Equipment & Supplies
May 28, 2008 | Brother HL-2070N Laser Printer
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Apr 04, 2008 | OKI C5200n Laser Printer
Feb 02, 2008 | Epson DFX-9000 Matrix Printer
78 people viewed this question
