Question about OKI Office Equipment & Supplies
Http://www.fixya.com/support/t2417505-oki_9600_fatal_error_917
Maybe this will help.
Posted on Sep 19, 2019
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
Posted on Dec 07, 2008
SOURCE: fatal error 917 on an Oki C9600 printer
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
SOURCE: How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on [email protected] and i will forward u the info.
good luck
Posted on Aug 29, 2010
Apr 06, 2015 | Oki Printing Solutions CX2633 LED...
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
May 27, 2011 | OKI C8800dn Led Printer
Apr 16, 2009 | OKI C5200n Laser Printer
Mar 15, 2009 | OKI C5100n Laser Printer
Feb 19, 2009 | OKI C3530N Color MFP Printer
Apr 15, 2008 | OKI C5500n Printer
Mar 07, 2008 | OKI C5300n Led Printer
Jan 29, 2008 | OKI MICROLINE 520 Matrix Printer
May 15, 2007 | OKI C5100n Laser Printer
121 people viewed this question
