20 Most Recent Lexmark C544dn Laser Printer Questions & Answers
Our lexmark c544dn has a
Pull back the fuser cover ( black upper area) and look for the jam beneath the black roller with paper sticking up - to pull it out
2/2/2022 3:22:22 AM • Lexmark C544dn... • Answered on Feb 02, 2022
106.08 service printhead error lexmark
Please click on the link provided below.
http://bitly.com/nIjA4L
If this does not resolve the issue, please try to reseat the printhead cable.
Turn the printer off, and remove the rear. Check the cable at JMIRR1 for shield. proper connection to the controller board, the printhead cable for pinch points, and the cable
or connector for any other damage.
7/31/2021 7:18:06 AM • Lexmark C544dn... • Answered on Jul 31, 2021
Won't use tray 2 when tray 1 is empty
Have you tried checking that tray 2 has the same paper type as tray 1. If your machine is network attached, you can access the embedded web server (where device settings can be adjusted) by entering the device IP address into a browser. Find the web address from the machine by going to menu (key icon), reports, then arrow over to network set up page. NSP is a 1 page report which will tell you the IP address. Go to a web browser and type in that IP address. Should take you to your device web page. From that page you can change the device settings (click on settings and then paper menu). Check to be sure that the same paper type is set for both tray 1 and tray 2 (and be sure that tray 2 is showing up on the list). I had to power the printer back on for it to recognize tray 2. Hope it helps
7/31/2021 7:15:52 AM • Lexmark C544dn... • Answered on Jul 31, 2021
2answers
Error code 900 Lexmark c544dn
900 errors usually point to fuser or fuser related component failure.
Please have the printer serviced.
7/29/2019 9:51:46 AM • Lexmark C544dn... • Answered on Jul 29, 2019
What does 200.04 jam error indicate?
Did you look the jam code up in the operators manual? might try going to the Lexmark web site and look up your model mite have a updated firmware that will fix that problem, also are you using paper that is authorized to be used with that machine? look up the spec in the op manual or web site, check the weight of the paper the paper draw rollers may be dirty clean with a small amount of soap and water. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
11/18/2015 4:18:34 AM • Lexmark C544dn... • Answered on Nov 18, 2015
I have a Lexmark C544dn printer. I am getting a
Check the transfer belt and clean if necessary with Isopropanol (IPA), and a soft clean cloth. Also check the drum for the same. Handle with extreme care as these are fragile and expensive. If none of those fix the issue you may need to get the laser lenses cleaned professionally.
4/13/2015 9:19:14 PM • Lexmark C544dn... • Answered on Apr 13, 2015
Toner out of ink. Can I bypass the color?
It is important to have toner in each of the toner cartridges, even if you don't use that color at all. The machine periodically `calibrates' by putting a very small amount on a belt in the machine. If it is unable to calibrate, it won't get ready. Also, if you run an empty toner cartridge for too long, it will begin to leak waste toner, and cause major problems.
4/3/2014 4:52:28 PM • Lexmark C544dn... • Answered on Apr 03, 2014
0answers
0answers
Lexmark C544dn Laser Printer Logo
88 questions posted
Top Lexmark Office Equipment & Supplies Experts
Marvin
Marvin
Mehandi Husain ...
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C Lexmark
  • C Lexmark
Most Popular Question
200 04 jam error grab paper
  • Office Equipment & Supplies
