20 Most Recent Lexmark C530dn Laser Printer Questions & Answers
2answers
960 service memory error - a
The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
7/31/2021 7:17:06 AM • Lexmark C530dn... • Answered on Jul 31, 2021
2answers
900.00 Service
When I have seen this error in the field, I have cured it by updating the firmware. Lexmark has a paper in their Knowledge Base on 900 errors:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
Go through the suggested steps to try to narrow the problem down.
But if it needs a firmware update:
http://support.lexmark.com/printerfirmware/
Use code: Isfap129 to download the package the C530dn.
Hope this helps!
7/29/2019 9:53:03 AM • Lexmark C530dn... • Answered on Jul 29, 2019
C530 Insert Tray 1
8db5o70lihgzmaaaaasuvork5cyiia
7/3/2017 11:49:01 AM • Lexmark C530dn... • Answered on Jul 03, 2017
Lexmark c530 print any page all in black as bakgroud
It is probably a faulty black drum unit. I would hazard a guess that something like a corona wire or Primary Charge roller is not transfering charge to the optical drum correctly.
4/13/2015 9:24:27 PM • Lexmark C530dn... • Answered on Apr 13, 2015
PINK LINES ON THE LEFT HAND SIDE WHEN PRINTED
How old are the pcr units (drums). sounds like either a problem with the magenta drum or the magenta toner cartridge is leaking.
9/19/2014 4:40:37 AM • Lexmark C530dn... • Answered on Sep 19, 2014
Too much red
Don't change the density / RET on your Color Laser Printer, you can adjust when necessary from your printer driver via your computer.This Magenta issue I see often in this Lexmark Printer, replacing the toner may help, but cleaning the contacts on the transfer belt and dumping the waste hopper, is the only solution.I would only use O.E.M. Toners on this printer.
9/18/2014 4:18:12 PM • Lexmark C530dn... • Answered on Sep 18, 2014
Error nvram mismatch on lexmark C532dn
Have you replaced any components on this printer? This error happens if you replace the display, engine card or interconnect card with one from another printer. Parts are not reusable.
8/8/2014 6:09:42 AM • Lexmark C530dn... • Answered on Aug 08, 2014
Why has the control panel gone blank
support.lexmark.com
6/13/2014 3:36:26 PM • Lexmark C530dn... • Answered on Jun 13, 2014
0answers
0answers
No display
Try to power cycle the printer Ii.e., power off and on).Verify whether machine has power (check fan, LED). Verify if fan is running. If fan is not running, replace LVPS (Low voltage power supply. Part # 40X5409. For further assistance please contact Lexmark Technical Support.
2/29/2012 1:06:26 PM • Lexmark C530dn... • Answered on Feb 29, 2012
Lexmark C530dn Laser Printer Logo
84 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C Lexmark
  • C Lexmark
Most Popular Question
service 960 memory error r
  • Office Equipment & Supplies
