20 Most Recent
Lexmark C500n Laser Printer Questions & Answers
LEXMARK C500 DRIVERS WIN 10
There are no drivers for this device for Windows 10 as they printer is 10 years old. There is supposedly a way to get it to work with Windows 10 using VISTA drivers. Here is the link to the MS Community question about it. You can try to use the instructions there. Good luck!
Windows 10 driver for lexmark c500n
Set transfer roll
Your printer doesn't recognise the transfer roller, it is either not fitted properly or one of the contacts have slipped off the frame.If you would like i can email you the service manual (it has some pictures of this in it) if you would like me to please reply with your email address.
C500n color problem
Try using another magenta/yellow cartridge.
Draw 4 rectangles colouring them 100% C, M, Y, and K and print.
Check the print and see which colour print is not appropriate
PRINTER SAYS TO SET TRANSFER ROLLER, NOT SURE HOW TO SET
Ensure transfer roller is properly installed.Turn printer off and check transfer roller contacts. Are contacts present and not damaged? If yes, Replace engine controller board. Otherwise, If contact A (please see attachment) has slipped off frame, put it back on. If you cannot see it, remove HVPS cage and put it back in place. If B is damaged, replace registration assembly.
Svc e3 ERROR
I had this problem - My solution remove all paper - then replace all paper that is creased, with uncreased paper!My printer now works fine
Error message Tray1 Load LTR
This meens a printjob was send to print on "letter" papersize, all though there is another papersize selected in tray 1.
Push the select button several times and the machine will print this job
Why Error message Tray1 Load LTR
Check the paper settings, tray is set to letter. Tray 1 is running our of paper, check paper guides and properly load paper on tray.
For further assistance, please contact Lexmark Technical Support
What is the problem when
Load ltr means to load letter size paper. If its saying try 1 load ltr - its saying that you are out of letter size paper in tray number one of your printer.
What does it means error
Scanner motor (SM) is rotating abnormally.I suggest you contact Lexmark Technical Support for assistance.
