20 Most Recent
Bosch 1000P NG AquaStar 2.6 GPM Indoor Tankless Gas Water Heater Questions & Answers
My water heater was working fine for 4 years. Then
You said you had the gas line checked does this mean that you had pressure checked to gas valve or beyond to burner. I would check on gas valve and see if there is a test plug.If so I would loosen it and turn thermostat up to call for heat and see if you get any gas flow.If you have gas at this pointthe ignitor does not work then replace ignitorIf it tries to light but won't then I would remove burner assembly and make shure orifice is clean.
If you have gas into gas valve but not out then you probably need to replace the gas valve. With being 4 yrs.old the parys should be covered by warranty.Best of luck and thank you
No gas through regulator
Before calling service technician, open following link for Bosch troubleshooting resources including online support, possible manual, and service bulletins.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.htmlRead manual for troubleshooting, advisories and required maintenance.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
We hzve natural gas ion oujr cabin but no
LOOK AT THE UNIT WHERE THE GAS GOES INTO THE UNIT IF YOU SEE SOME KIND OF A SPARK PLUG WIRE YES YOU WILL NEED ELECTRIC FOR THE UNIT TO FIRE, MOST OF THE UNITS HAVE WHAT THEY CALL A STANDING PILOT LIGHT WHICH STAYS LIT TO IGNITE THE GAS WHEN NEEDED. LOOK AT THE UNIT FOR INFO FOR VOLTAGE THERE HAS TO BE SOME KIND OF TAG FOR THIS TO COMPLIANT FOR SALE OF THE UNIT
Why is the Bosch high flow 21e system while showering going cool & then returns to the set temperature?
If your Bosch Highflow 21e hot water system is experiencing fluctuations in water temperature while showering, it could be caused by a few different factors. Here are some possible reasons for this issue:
- Flow rate too high: The hot water system may not be able to keep up with the demand if the showerhead or tap is allowing too much water to flow through. This can cause the water temperature to drop suddenly. Try reducing the flow rate by turning down the tap or using a low-flow showerhead.
- Water pressure fluctuations: If the water pressure in your home fluctuates, it can cause the hot water temperature to vary. This can be caused by various factors, such as other appliances using water at the same time, or changes in municipal water supply pressure. Installing a pressure regulator or a flow restrictor may help to stabilize water pressure.
- Blocked or dirty water filter: A clogged or dirty water filter in the hot water system can restrict water flow, causing the water temperature to fluctuate. Check the filter and clean or replace it if necessary.
- Malfunctioning thermostatic mixing valve: The thermostatic mixing valve (TMV) regulates the water temperature in the hot water system. If it's faulty or dirty, it can cause temperature fluctuations. A licensed plumber or technician can inspect the valve and replace it if necessary.
- Faulty temperature sensor or control board: If the temperature sensor or control board in the hot water system is faulty, it may not be able to maintain a consistent water temperature. A technician can diagnose the issue and repair or replace the faulty component.
If you're unsure about how to diagnose or fix the issue with your hot water system, it's best to contact a licensed plumber or technician for assistance.
No water coming out of hot water taps with a Bosch Water Wizard 10P?
Do you live in a climate where the hot water line could have frozen? If your heater did freeze up, that could be very bad. This is because water actually expands when it freezes and can do a lot of damage to pipes and to the water heater itself. My other thought is possibly a clogged in line water filter. But typically a clogged water filter would make it run with reduced pressure rather than a complete shutdown all water flow.
Bosch AquaStar 125b suddenly goes cold
your not making sense with you question --state it goes cold in middle of shower --but state it will stay hot or cold forever ----if its the latter continued hot till you shut off water that normal working if the unit shuts down during shower then you have a problem ----unit is set at one temp and runs at that temp and you use shower 1 handle / 2 valve what ever you own to adjust temp their are really only 4 reasons stops making hot water ----2 are usually well water supply --incoming water pressure /flow or to cold ----other are gas valve -or sensor so i would look into your shower handles since almost all have adjustments and anti scold safety
