20 Most Recent Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Questions & Answers
It should be producing hot water at the temp it was set at such as 120-140 degrees. If it is exceeding this one of the safety devices maybe disconnecting it. Thermal control might need some servicing. See what temp it's set at then put a thermometer on a near water outlet to see what's going on. Good luck.
Bosch PowerStar... | Answered on Sep 06, 2015
I just tried to replace one of the o-rings on an AE125. The old original one came out distorted do to the fact that there's no groove to hold the o-ring in a uniform position.
Even though I was careful and evenly tightened the cap screws,
the new o-ring started leaking an hour after I had left the job.
My opinion is the mounting of the metal lid to the plastic tank is a bad design.
Good luck on your repairs.
Bosch PowerStar... | Answered on Feb 26, 2015
It sounds like you have a copper canister unit. Ohm out the elements in that one canister. the directions are on the websight for bosch, or I can walk you through it. But you will need a digital multimeter to do this. If you have a blown element in that one canister, then the tco will not reset.
Bosch PowerStar... | Answered on Dec 13, 2014
Replace heater?
Do not install tankless.
Call for service?
Manual does not show troubleshoot or repairs
Bosch site does not show the AE125 series water heater any longer
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Bosch PowerStar... | Answered on Oct 20, 2014
Light flashing while water is flowing means you have a bad control board. Needs to be replaced. They can be purchased online
Bosch PowerStar... | Answered on May 06, 2014
Control unit or flow transducer. If the transducer(impeller in the clear tube) is spinning freely with waterflow, then the circuit board needs to be replaced.
there are no valves in the unit. You can only regulate waterflow through this machine with self-supplied ball/gate valves
Flashing light means bad control unit..or your flow is too low. If you have a couple fixtures on, and its still blinking, the board needs to be replaced.
Hey Andy. Do you have your owners manual? There should be a section near the back that will break down the diagnostic code the flashing light is giving you. If not remove the front cover and look inside should be a wiring diagram and light legend.
Bosch PowerStar... | Answered on Dec 15, 2013
Bosch PowerStar AE125 AE125 Whole House Electric Tankless Water Heater... Logo
95 questions posted
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Bosch Water Heaters
  • Bosch Water Heaters
Most Popular Question
left red button constantly reset also
  • Water Heaters
