Water Heaters Logo
Question about Bosch Water Heaters
No water coming out of hot water taps with a Bosch Water Wizard 10P?
Hi, I have a Bosch Water Wizard 10P. I filled my kitchen sink up this morning and had hot water. 10 mins later I go to run my shower and no water whatsoever came out from the hot water tap. I then checked every other hot water tap in the house and the same problem occured. I checked the hot water system and I can see no sign of any leaks. What do you think the problem may be?
Posted by Renee Ransom on
Michael Sabo
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Do you live in a climate where the hot water line could have frozen? If your heater did freeze up, that could be very bad. This is because water actually expands when it freezes and can do a lot of damage to pipes and to the water heater itself. My other thought is possibly a clogged in line water filter. But typically a clogged water filter would make it run with reduced pressure rather than a complete shutdown all water flow.
Posted on Jan 20, 2023
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Hi I have a Bosch water wizard 10p & although i have the heat turned up to the highest it is still not hot enough! I was wondering if there was another way of increasing the water temp?
Open following link for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Typical Bosch 10P manual shows temperature control illustration on Pg4, and includes low water temperatures on troubleshoot on Pg6
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
Water flow rate too high, low gas pressure, faulty thermostat.
Two other things might be causing problem
Crossover:
http://waterheatertimer.org/Crossover.html
Lime build-up
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
2helpful
I have a Bosch Water Wizard 10P - have no hot water, no water comes out the hot water tap, can't light Pilot Light, not sure where to start would love a step by step diagram how to start pilot light -...
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
Before calling service technician, read manual for fault finding and possible solutions.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdf
http://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdf
Following links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_going
http://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keeps
http://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water
1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspx
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#
3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Add a comment with your experience so others with same-similar problem can benefit.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Bosch water wizard 16 - gas still runs after water tap turned off
Sounds like a flow sensor may be bad. It may be registering flow when there is none and it sending signal to ignitor and gas solenoid that there is.
2helpful
2answers
Water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
3helpful
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
1helpful
Water pump does not work when i turn on hot water tap
Since the cold water works, the problem is not the pump. Look for a blockage or possibly a major leak in the hot water system. if you have a kitchen sink and bathroom sink, are both hot water outlets not working? Does the water heater have shut off valve , or is its drain still open from when you winterized it (and the water running out to the ground instead of to the faucet?
Running water in 2 sinks just to get hot water from a bosch
you can put in a circulatating pump that is controller with a timer and a thermostat so the when yo need heat water the most its readilly available and when you don't it's off, the only thinsg thing that you would have to do it tye in the supply and the return and then insulate the pipes.
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
David Shaub
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
