Water Heaters Logo
Ricky Stull Posted on Jun 14, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Bosch Aquastar GWH 2400 CTD EFS LP is there a conversion kit to convert it to NG?
ENFORCER
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Bosch Master 38,673 Answers
  • Posted on Jun 14, 2021
ENFORCER
Bosch Master
Level 3:
One Above All:
Top Expert:
Answers
38673
Questions
0
Helped
270598
Points
1310177
Most likely. contact a dealer for advice
How do i gas heater gwh 2400 ctd efs Lp
Stupid me but could you be a little bit literate in asking a question.
My dog write better questions that I can understand than this scribbling.
A GWH 2400 is the little brother of the GWH 2700 much like the 635ES. If you have an LP model be sure to use the overpressure protection valve supplied by Bosch as overpressure in LP (above 10-14" WC) can completely destroy this unit.
And you can use a TPR or PRV for 170,000+BTU being sure you get a House Pressure valve of 60-80-100 PSI+ and not the boiler PRV for 30 PSI
Beyond that your questions above states nothing recognizable as a technical question
Need to convert 2700ES from NG to LP and just purchased the conversion kit. What is the proceedure? Can not find a Bosch tech to do the conversion in this area (12430). I am told that I need special...
I don't have good news.
You are attempting a conversion that local technicians are refusing to do.
There is a reason why we service guys steer clear of some things: liability and continual problems afterward.
Contact Bosch and find the service bulletin for that procedure.
After all this is a highly technical and finicky machine hooked to a gas line located in proximity to people.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
If this procedure is going to cost more than $400-600, and remember there is a risk it will not work afterward or will be a continual problem, then consider installing tank-type LP water heater from local box store. I recommend this.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
For others in same situation: NG to LP conversions are not supported or recommended by every manufacturer. This applies to tank and tankless.
Also check there is a qualified service technician in your area before installing tankless.
Read the manual before buying.
Tankless gas savings are $1-8 per month, but all costs are energy.
Tankless cannot be exposed to more than 11 grains hardness in the water.
Tankless are maintenance heavy, and with expected repairs, maintenance and cost of parts, cost of machine and replacement cost, a simple tank-type water heater is cheaper by far.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
I have a bosch gwh 2400 es ng and when i program the temp. it resets back to 100 degrees
Before calling service technician, open following link to download typical manual, get Bosch contact information etc.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
I have a Bosch GWH 2700 CTDR EFS NG and the water will not get hot and if it does, it's only for a brief moment.
A lot of factors, internal and external, can cause this problem ranging from bad PC board to plumbing problem.
Since you have no error code, it could be plumbing,
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open following link for useful Bosch troubleshooting information including Bosch support and typical manual for 2700 gas tankless:
For folks with Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
I have a Bosch GWH 2400 CTD EFS NG tankless water heater. It has been installed on operating for over a year in the last several days it has an error code A3. The first two times I was able to reset it....
Call qualified service technician, and ask that person questions about maintenance and tips.
Then keep service technician number in rolodex-wallet.
Resourceful do-it-yourselfer will find following links handy.
Tankless are maintenance heavy, and Bosch and Rheem etc say to call service technician for recurring problems. Especially when short-hand troubleshoot section doesn't solve problem.
People spend years learning how to service tankless.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes online:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Bosch problems at Fixya:
Open following links and read about tankless problems to understand the field and glean useful information.
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Install DIY tank-type gas water heater and avoid the whole headache
Post question on pro water heater forum: This is where I go to catch up on latest info in always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for an answer at fixya:
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
BOSCH error codes:
Add a comment for more free help.
I need to convert this water heater to natural gas. Is there a kit available to do this?
No kits are available to convert his unit to NG. This is because the LP uses copper pipe and is within code, the NG uses black pipe and each unit is specifically designed, entirely, to use the gas associated with the unit.
Error codes re: fan speed fan very noisy
I was looking for a service manual, which you apparently do not supply. I was not looking for someone who will charge me a fee to get information. I can get that info directly from Bosch for free. Thank you for answering. John
2helpful
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
