SOURCE: necesito el drivers de la
u can find the drivers for vista here - http://support.creative.com/downloads/download.aspx?nDownloadId=10119
SOURCE: necesito instalar mi wed cam pero no tengo el cd
Espanol: (English below)
Muchos sitios en línea tienen capacidad para detectar y buscar los controladores. Usted podría intentar una de ellas.
Sospecho que su cámara web ya no es soportado por Creative Labs.
Si la webcam es USB, puede ser capaz de salirse con la suya utilizando un software diferente. Usted podría intentar encontrar driver para VF-0450. O, incluso un competidor como el software Logitech QuickCam. Este último es utilizado por varias cámaras web.
Por último, una nueva cámara web puede ser la mejor respuesta.
English:
Many sites online have ability to detect and search for drivers. You could try one of those.
I suspect your webcam is no longer supported by Creative Labs.
If webcam is USB, you may be able to get away with using a different software. You could try finding driver for VF-0450. Or, even a competitor software like Logitech QuickCam. The latter is used by various webcams.
Lastly, a newer webcam may be the better answer.
SOURCE: necesiti el drivers de la web cam creative vf-0040
Copy this site and paste it in your web browser and hit ENTER.
http://support.creative.com/downloads/download.aspx?nDownloadId=10286
This is a driver update for your Creative WebCam Live and can download the Creative Camera VF-0040 Drivers. For 98, ME & XP but not sure if it will work with Vista. Be aure to
select the operating system to get the proper driver.
After you scroll down on the Agreement, then click on AGREE and the download will appear. Click on SAVE.
Then to install the drivers do the following:
DISCONNECT the camera from the USB port and install the CD Soft program or the Downloaded program.
When the program asks you to connect the camera to the USB port, THEN DO SO.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
SOURCE: necesito los driver y el firmware de este modelo
hola tu tienes sorte que jo ablo en spainhol jo ablo en tres lingures .
aqui estas seus driver e firmware link
se ajudar tu rate a mi solution.
