The following link can give you some advice on common causes of front
loader washer odors and some preventive measures you can take to keep
them from coming back:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most common causes of persistent odors comes from not leaving the
door OPEN between washes. The manufacturer recommends this to allow the
wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL.
Leaving the door open will NOT make this water evaporate, but will
allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the
rubber door bellow and/or drain pump. It is recommended that you pull
back the rubber folds in the door bellow (gray rubber seal) and check
for dirt, debris or small articles of clothing that may have become
trapped there. Socks are a common thing that become trapped, and if
left for a long period of time, become stagnant. The drain pump
reservoir is another common place for things to collect and become
stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
All these are preventive measures that can drastically prevent odors,
mold and mildew. Read through the advice given and post back and let me
kow if you require additional assistance. I hope you find this
information helpful.
I have the same odor problem and my dark clothes are constantly covered with lint.
