It is repairable, but generally involves you having to open up the PS3 and mess/replace some parts, which I would not recommend doing.
I would instead recommend sending your PS3 into the Sony support team, and having them fix it. If you're still covered by warranty it will be free, and if you're not it will still be cheaper than buying a new one. Also, Sony should fix it in a way so that it will not overheat again.
To start the repair process, go the Sony's website and find their support page, they will guide you from there.
if you get the
3 red lights then Microsoft repair your console for free so long as you
purchased it no more than 3 years before you send it back for repair. The 3 red
lights are a sign of overheating, and to go into more detail this is what
happens:
The 360 had a manufacturing fault or air vents
were covered and so the 360 overheated, and got so hot that the solder balls on
the cpu or gpu chip melted, and due to the fact the the 360 motherboard is able
to flex a little, when the 360 was turned off and cooled down these solder
balls solidified again, however they solidified in the wrong place or in two half's
etc. and so the 360 shows the 3 red lights to indicate this fault.
Click here to download Microsoft xbox360 repair guide
firstly if you
get the 3 red lights then Microsoft repair your console for free so long as you
happens:
If it is 3 red
lights, the most common fault, then here is a little explanation:
firstly if you get the 3 red lights then microsoft
repair your console for free so long as you purchased it no more than 3 years
before you send it back for repair. The 3 red lights are a sign of overheating,
and to go into more detail this is what happens:
halfs etc. and so the 360 shows the 3 red lights to indicate this fault.
