Samsung RS2534 Side by Side Refrigerator Logo
Anonymous Posted on Jan 30, 2011
Fridge leaking water inside. - Samsung RS2534 Side by Side Refrigerator
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Jan 30, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953473
Points
6173
Check frosting over would have clogged the drain pan. Unplug unit and wait for sometimes until defrost is over. Then run the unit. Please confirm, defrost timer,thermostat and heater are working properly to get auto defrosting time to time.Thanks.
Testimonial: "We found thermostat stuck. We'll replace. Thanks for helpful msg"
poonam sharma
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 16, 2014
poonam sharma
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
520
Points
Sir, My samsung referigerator temp. knob become freezed. Pl. tell me reason.
1helpful
Samsung Fridge Freezer Model RT77KBTS leaks water from the inside and somehow runs down the back of the inside from unknown location then pools up inside at the bottom and eventually runs out of the...
i had this problem .. there is a drain in the freezer it drains condensation through a hose to a pan at the bottom where there is a fan .. that fan splashes this water onto the condenser coils to cool them.. if that hose gets plugged then that water gets diverted and drains into the inside of the fridge... the big problem is this water is no longer cooling the condenser coils and your condenser will run hot until you clear the clog and get this working right again.. i had to unplug the fridge and let everything get warm (a few hours) then run a flexible wire through the hose at the bottom (fan) to the top to loosen the clog then run clean hot water through it to clear it completely . it's no small task but you might have saved yourself buying a fridge and loosing all that's in it ..
2answers
I have a water leak inside of my maytag fridge and it leaks out onto the floor from the inside. What is the couse of this problem?
Have you checked to see if your condensation tray is too full? The tray will be located at the bottom of the fridge and should slide out easily.
1helpful
2answers
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
1helpful
2answers
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 • Freezers
Water leaking from underneath fridge
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
1helpful
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
1helpful
2answers
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
