SOURCE: Can't connect through a wired connection to modem..help
Looks like you figured it out, but here you go!
http://www.pchell.com/support/limitedconnectivity.shtml
SOURCE: Toshiba A205-S5819 Can't connect to wireless internet
The router you're trying to acess may not be set up for Vista or may not be compatible with Vista. I had to upgrade the router at my shop in order to work on Vista OS machines.
SOURCE: Keep losing internet connection
Recommendation: If you can switch from the 3rd party wireless utility to the Windows utility. There should be a check box under the properties that says, "Let Windows manage my connection." Also turn off any power management that stops your drives, suspends the machine, etc. When doing WEP, use the actual key, not your password. i.e. the one that looks like "aaff996753bc" not "rosebud".
Reason: Windows wireless starts before you even log in and loads as a service, it runs whether your logged in or not, sleep mode, etc. 3rd party utilities...especially my personal bane of all wireless devices "Netgear" load as applications. That means they don't initialize until after log in and they can be suspended completely or prioritized by power management and resource management utilities when the machine is idle. As for the key thing... WEP translation with Linksys especially can be a little funny with some wireless so I use the key itself which always works.
SOURCE: wireless connection on qosmio G25-513 not working
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically
then enable in your intel pro ipaddress properties auto get ip addrese.
thats it.
SOURCE: Sony laptop won't reconnect to wireless router
You need to go into the properties of the wireless connection and set it to automatic connect, somehow the information was removed, maybe you disconnected, which often puts the connection back to manual. by reconnecting it often fixes itself.
