You are low on freon - shut unit off and don't run it or you can burn up the condensor. Call technician to install freon and dye so they can locate the leak after it has circulated the unit. Make sure unit is not iced up when the technician comes out. This is a minimum 2 service call fix. How old is the unit? If it's 15 years or older, you might want to consider replacing unit.
