Tip & How-To about Refrigerators
Refrigerator Compressor Start Capacitor and Start Relay
Many people have had problems with their refrigerator compressors not starting and wonder what may be the problem. Many times the problem can be traced to the start components. The start relay and the start capacitor work together to help the compressor get started. By giving it a short extra shot of higher voltage current, it gives the compressor the kick to get it turning up to speed.
The capacitor is the long round tube on the top of the box that houses the compressor terminals and the start relay.
The start relay is pushed right onto the compressor terminals C and R. It also has two wires that go up to the start capacitor.
The relay can be removed by just pulling out on it away from the compressor off of the pins.
If your refrigerator compressor is not starting, you can change the start components easily, to see if they are the problem. Usually you will have about a 50-50 chance of the compressor working again by changing these parts.
If you are looking for the configuration of the compressor terminals, here is a picture of the terminal cover that shows which terminals are where.
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
Refrigerators Logo
the unit compressor will not run, wondering if it's a component that supports the compressor or the compressor it'self. how do I tell? there is some clicking within a white component mounted on the compressor. any easy checks before I chuck the thing and buy a new one?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Refrigerators
Not cooling. Fan runs fine. Gets very warm if left on for a period of time. Model number is 5232
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Pull the front grill off of the refrigerator and wash that out. Then if you have a good vacuum with a crevice tool, reach in from the front and the back of the refrigerator to remove as much of the dust and dirt as possible. Often I will then use my air compressor to blow out more of the dust and dirt and continue to vacuum as needed. Use patience as you do this, as it will take time and blowing from both the front and back a number of times to really get the coil to clean out.
Now that you know what to do, why wait for the warm weather and for the refrigerator to start acting up before cleaning the coil? Get out the soap and water, the vacuum and air compressor and clean it out now. The cleaning will also help your refrigerator to run more efficiently and save you money.
All the things in your refrigerator are getting warm. The freezer is thawing and when you listen closely you hear a click with a buzz, another little click and then nothing for a few minutes. Then the same thing starts all over again. You fear the worst and you are probably correct. The compressor has decided that it will not start anymore.
When this happens, sometimes it is the fault of the capacitor or the start relay. There is about as good a chance that changing these start components will work as it is that it will not work. If you can do the changing your self then you should get the parts and do the work. You have half a chance that it will work. If you will need to pay someone else to do the work then you need to look hard at what it will cost you and what the unit is worth, then decide to take a chance or not.
If you do decide to change the start components then you need to make sure that you unplug the refrigerator long enough the let the compressor cool completely. Even with new components a hot compressor often will not start. Believe me if your compressor is trying to start and can't then it will be very hot!
Jun 18, 2011 | Coleman Electric Cooler 40 Beverage Cooler
the refriderator had been making clicking noises for quite a while and i s wondering what is was, every ten minutes or so it sounds like a motor in the back clicks on and vibrates very loud for about 6 seconds and clicks off, is my refrigerator about to break completely or is it a maintanance problem??
That sound you hear is your compressor trying to start. You will notice that the freezer temperature will begin to get warmer, while the fresh food side "seems" ok, but it wont for long. Now the problem might be the compressor itself, or the start device which starts the compressor. You will have to either buy a start kit and hope that is it, or bite the bullet and call A Fast Local Refrigerator Repair service and have them test your compressor.
Dec 10, 2010 | Refrigerators
I have a inglis fridge which is only 4 years old. It has a freezer compartment as weel as the main. Seems like the freezer has stopped working. water is now dripping from top part of frigde. Was wondering what the problem is?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 07, 2010 | Refrigerators
73,904 people viewed this tip
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
