Home | Fujitsu | Air Conditioners
Fujitsu 18C1 Air Conditioner
Problems with Fujitsu 18C1 Air Conditioner?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Fujitsu 18C1 Air Conditioner RSS Feed
Click here to get instant support from our best Experts!
View More Results for Fujitsu 18C1 Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Fujitsu 18C1 Air Conditioner RSS Feed
Answer
BlinkingLED error codes for ductless split. Looked in manual as wel as on wall unit but can not find... (More)
Answer
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries... (More)
Answer
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues... (More)
Answer
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split... (More)
Answer
I have power to the indoor unit,but the operation light does not come on
Answer
fujitsu inverter heater not working,timer light flashes 3 times in intervals when turned on.
Find a Manual
Fujitsu 18C1 Air Conditioner Manuals & Guides
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for 18C1 Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Find an Expert
Meet our 2629 Air Conditioner Experts
dmftrucker
Rank: GuruGuru
Rating:  87%, 401 votes
Solutions:  1582 (485 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
projdoc
#2: projdoc
Rank: GuruGuru
Rating:  94%, 598 votes
Solutions:  1178 (455 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
roniecon
#3: roniecon
Rank: GuruGuru
Rating:  88%, 635 votes
Solutions:  2126 (395 Votes in the last 30 days)
Experience: A S E certified /35 years experience
justaskjoe
Rank: GuruGuru
Rating:  85%, 1975 votes
Solutions:  3800 (338 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
57 varieties
Rank: GuruGuru
Rating:  88%, 509 votes
Solutions:  1495 (340 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
localwonder
Rank: GuruGuru
Rating:  92%, 2764 votes
Solutions:  4883 (317 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
avid101
#7: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1136 votes
Solutions:  2415 (285 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
techbuster
Rank: GuruGuru
Rating:  89%, 485 votes
Solutions:  1090 (267 Votes in the last 30 days)
milten1
#9: milten1
Rank: GuruGuru
Rating:  90%, 472 votes
Solutions:  1304 (222 Votes in the last 30 days)
Experience: 15 years field experience and 5 years navy training
buffalonyman
Rank: GuruGuru
Rating:  85%, 709 votes
Solutions:  1816 (223 Votes in the last 30 days)
Experience: Licensed Master Electrician for 25 years, Plumbing, HVAC, Custom Build Computers, Automotive
Find a Warranty
Specifications for Fujitsu 18C1 Air Conditioner
Key Features
Type
Split System
Remote Control
With Remote Control
Cooling Capacity
18000 BTU/hr
Energy Efficiency Rating
11 EER
Fan Speeds (Cooling)
Dimensions
Depth
7.69 in.
Height
12.59 in.
Width
49.22 in.
Fujitsu Contact Information
Main support number(866) 952-8324
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
