Video Game Consoles & Games Logo
Posted on Jan 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Xbox 360 wont turn on, power brick light is a constant orange. I used my voltmeter and all components are receiving 60volts but nothing turns on.
Anonymous
Level 3:
  • Master 492 Answers
  • Posted on Jan 02, 2011
Anonymous
Master
Level 3:
Answers
492
Questions
Helped
142841
Points
1567
Try these steps from the Microsoft website:
http://support.microsoft.com/kb/906102
My xbox won't turn on I have an orange light on
blow out the brick power supply with air
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
When i plug the xbox up the light on the plug adaptot turns orange and the xbox wont turn on
This is usually caused by the power brick over-heating. Try cleaning out the vents on the power brick. There are little holes on the ends and overtime they become clogged with dust and lint. If that doesn't work then you'll have to replace the power brick.
My xbox 360 had gotten the red ring, so I heated the mother board with a heat gun and then replace the thermal paste, now the power brick is orange/yellow when plugged in, turn on the box it goes green for...
We STRONGLY recommend you not to use heat gun as it can heat other components, when your system have 3 red light and no fan are spinning it means that one of your fuses has gotten damaged and no power can go through your GPU chip.
Thanks
www.1RepairStop.com
We Fix Everything
Orange light on brick plug it into my xbox and light goes red and it wont switch on
the 360 has a power fault usually it is drwaing toomuch power for the relay in the brick to switch over, try removing the hdd and any wired controllers you may have in it and see if it will turn on
Xbox 360 won't turn on!! I was playing my xbox for all of 30 minutes, turned it off, went to turn it back on again an hour later, and nothing!! No red ring of death, no pop or spark, just nothing....
try this
I know its a little annoying but its useful trust me. The orange light usually means a problem with the power supply. This means WORST CARE SCENARIO you have to replace the power brick but you 99% dont have to get a new xbox.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/power.aspx
cheers!
1helpful
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
1helpful
2answers
My Xbox 360 won't turn on. When I plug the power cable into the wall, the orange light on the power brick lights up as normal, but if you plug the other end into the Xbox, the orange light starts blinking....
Sounds like a bad power supply, or on two occasions I have found that one of the USB ports had a bent pin which was shorted to the metal housing, which wouldn't let the unit power on. So check all of the USB ports
My Xbox's Power Brick is Orange and My Xbox Won't Turn On. What Do I dO tO tURN iT bACK oN ?
try using another power brick if it still wont turn on then send it to Microsoft if its still in warranty if not run over your xbox and buy a ps3 and never look back at your xbox
1helpful
My xbox 360 wont turn on al all(not rrod)
Have you fully unplugged it and as in the mains from the adaptor, adaptor from the 360 etc? then re-plugged it?
If this does not help then i think you may need to visit http://www.xbox.com/en-GB/support
Top Video Game Consoles & Games Experts
Aron
john h
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
