I'm assuming that you are speaking of a snow blower auger. It most likely has sheared a cotter pin or bolt that couples the auger to it's shaft. Turn the auger slowly looking for a small hole somewhere along the shaft. When found, hold the auger and turn the impeller by hand until the inside shaft lines up it's hole (there may be a sheared piece of metal in the shaft hole). Use a pin punch to drive out any remaining shear pin and fit a recommended new pin or bolt. Hope this helps!
Have you tried taking your ice bin out and checking for
melted ice that can freeze locking the auger and preventing its movement?
Another item to check is wiring going to and from the dispenser. Many times
corrosion sets in the pin plug just behind kick plate. If the auger motor is
not turning at all then I would believe that you may have a defective door
light switch that also controls a lockout when door is opened. That light
switch tells when door is opened while the opposite happens when door is closed.
If that fails then we need to see how much voltage is present at the auger motor leads just behind the rear panel of your freezers auger motor assembly. To test the auger motor leads you need to have someone hold door light switch in and press dispense ice while someone checks motor leads with a voltage tester. If you have questions I will be glad to answer them for you, Thanks, Sea Breeze
