Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to...
(More)
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to run all the time. The temps are OK. What elst should I look at
when you open the refrigerator the inside light sometimes comes on and sometimes it dosnt. i...
(More)
when you open the refrigerator the inside light sometimes comes on and sometimes it dosnt. i replaced all 4 lights i thought i fixed the problem but its still happening, any thoughts? also when i flick the little switch inside the bulbs light up whats going on?
I can't get at the light bulbs to change them in my Subzero side by side. Its any older model and...
(More)
I can't get at the light bulbs to change them in my Subzero side by side. Its any older model and apiece of glass covers the bulbs but I can't figure out how to remove it. Can anyone help me?
when i close th refridge door i get a groaning sound like a motor is stuck, it goes away, but i'm...
(More)
when i close th refridge door i get a groaning sound like a motor is stuck, it goes away, but i'm concerned it will need to be replaced, any idea what it could be
Lights were out, so I replaced them but none of them light up and the fan is off so are the panel...
(More)
Lights were out, so I replaced them but none of them light up and the fan is off so are the panel lights. I cant find the internal fuses. Can this be done by me or do I need a repairman?
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
