20 Most Recent Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Questions & Answers
What is the model number that is listed in the refrigerator section?
Whirlpool 25.4... | Answered on Dec 19, 2018
Probably you have a bad power supply for the refrigerator or your condenser doesn't operate but wait a minute you said that you're not even receiving power so probably go with the power supply for the unit
Whirlpool 25.4... | Answered on Feb 06, 2018
i don't understand what you're discribing but if one of the lines are frozen you can use a hair dryer to melt it,put heat on for like a minute and take it off,you don't want to damage any of the plastic parts.
Whirlpool 25.4... | Answered on Oct 02, 2017
This could be a build up of lime scale
Whirlpool 25.4... | Answered on Jun 03, 2017
If Fridge working fine now, the problem may be is Hydro Grid.
When the fridge just start, the compressor is running with high pressure of Freon. If Hydro power has voltage surge or power Off/On ( suddenly ), the compressor should be stuck, the overheat protection switch will actived, than fridge will stop working.
The noice of "click" - properly is overheat switch auto-reset.
Whirlpool 25.4... | Answered on May 28, 2017
Control board is programmed unplug fridge to reset board if programming is required you have to remove front display cover and remove board there's a plugin on front of board programming tool required you may find it is cheaper to buy new board
Whirlpool 25.4... | Answered on Dec 19, 2015
ICE MAKER not making ice:
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Whirlpool 25.4... | Answered on Apr 17, 2015
I\'ve been struggling trying to keep our 2 goldens dog hair from the coils of our 8 year old Kenmore side by side with "W" compressor coils, but like everyone else was unable to clean past the first set of coils.
I came up with this solution that worked to get much of the big stuff, hair and bunnies, off of the further back coils. Not perfect but much better than nothing.
Removing the back lower panel I was able to snake a crevice attachment from our vacuum down the right side of the coils (left side looking from back)
Looking from front"
I made a compressed air contraption to blow the dust/hair across the coils using a compressed air nozzle that I added a 10" long tube and a 90 degree deflector
From the front of the fridge, on the left side of the coils, I snaked the compressed air nozzle towards the back and started directing the air stream blowing towards the vacuum crevice tool at the opposite side of the coils.
The compressed air dislodged the hair/dust enough that the vacuum was able to suck it away. Again, not perfectly but certainly much better than I was able to clean the coils in the past.
I suppose you could use a can of compressed air and add some sort of deflector if you don\'t have a compressor.
I then got to thinking how to prevent the dust from accumulating on the coils, I\'m going to try an air conditioner filter. I cut it slightly oversized to fit the front opening then split it in half to make it thinner for more air flow.
7a2fbc41-ef6b-4a4c-8961-a892df9da8ab.jpg 938facae-8d39-4f2b-b07c-82f5e4219751.jpg
Picture taken before making the filter thinner.
For years I had my calendar remind me monthly to vacuum the coils but now hopefully I\'ll be able to simply change the air filter.
Whirlpool 25.4... | Answered on Nov 15, 2014
Hello. May be the ice maker is overloading water. Is simple to regulate. You must take away the front cover from the ice maker, then will see a regulator screw, move it about 1/2 turn to minus posicion and check if water still leaking from the ice machine. Or maybe the water valve is damaged and never stops the water inlet
Whirlpool 25.4... | Answered on Oct 27, 2014
If you are getting ice then you still have a water supply. If not then make sure the water is turned on behind the fridge. I would next check for power to the solenoid when the door switch is pushed. Then check to make sure there is power to the switch. My best guess it that you have a faulty door switch or the wire was accidentally loosened or taken off when the person was working on the ice.
Whirlpool 25.4... | Answered on Apr 14, 2014
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
369 questions posted
Top Whirlpool Refrigerators Experts
Sal De
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
knocking noise about every hour or
  • Refrigerators
