SOURCE: canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
SOURCE: install
ok first u go to the google and write the canon ip 1980 printer driver and after install the driver and run this folder.. after install the driver printer working ok
SOURCE: Your Problem: canon ip service error 6a00
Had this error and did the following to solve the problem.
Turn the printer off.
Open the top cover and move the printer cartridge to the left.
On the right you can see a white part.
Press it down.
Turn the printer on.
if that doesnt help then there its better to call canon...
thank you
have a nice day
