Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Sep 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control Lock stays on no matter what I do - Whirlpool Duet GHW9150P Front Load Washer
Anonymous
Level 3:
President:
  • Master 1,430 Answers
  • Posted on Sep 16, 2010
Anonymous
Master
Level 3:
President:
Answers
1430
Questions
Helped
308379
Points
4820
Press and hold the end of cycle button for 15 seconds. This should clear it.
tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Frigidaire control lock stuck
Door is open but lock on the control panel won't do anything even if I close the door of my washer how to fix this can't wash clothes because the lock is displaying I tried everything
2helpful
Control lock stays on
  • 1
    Examine the control panel and locate the "Control Lock" button, sometimes located next to the "Lighticon1.png On-Off" button.
  • 2
    Press and hold the "Control Lock" button for a few seconds until the small red LED goes out.
  • 3
    Make your changes to the refrigerator'sicon1.png controls, or use the water and ice dispenser. Repeat step 2 to restore the control lock.
  • 0helpful
    Control Lock
    The following link explains how to clear a control panel lock problem on a Kenmore Elite:
    http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
    Hopefully this is just a simple matter of operator intervention. If this does not correct the problem, please let me know. I hope this helps you.
    Power will not stay on
    I had the same problem. Then I noticed on the back of the player was a "lock" button. Once I turned it to unlock, the problem was solved.
    Lock switch stays on
    The light goes on to indicate that the shift lock is engaged, so all letter type in upper case (capital) letters, or on machines with "spell check" to indicate a mis-spelled word. It should go out when you hit eithor left or right shift keys, correct the mis-spelled word or just continue typing.
    If it just stays on all the time no matter what you do, there is a problem with the main board.
    Door lock light on
    The lid switch is defective, and you need to replace it.
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
