Philips Magnavox 27MS343S 27" TV Logo
Question about Philips Magnavox 27MS343S 27" TV
Nikai japan ntv2190stf no working remote control
No working remote control and no open childe lock
Posted by sanu on
    Top Expert:
  • Philips Master
  • 76,851 Answers
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Posted on Dec 02, 2013
1 Related Answer
Anonymous
SOURCE: child lock
hi.... i did child lock my tv magnavox and can't turn on ,,,because my remote control is broke now.. so tell me please how could turn on my tv Please Tanks...
Posted on Feb 20, 2008
I have nikai tv model no ntv3272Led8. I dont have remote for this & i buyed new universal remote but its not working. Can u tell me how to setup tv to remote
No one buys universal remotes these days, you buy a remote that is an exact copy of the one for the television
Replacement Remote Controls - Your #1 Source For New Remotes
Ad·www.remotes.com/replacement/remotes
+1 800-736-6837
Best Price Guarantee on Remotes. Find Any Replacement Remote Controls. Fresh Batteries Included. All Brands & All Models. Free Ship Code: JUNE2017. 1 Yr Money-Back Guarantee.
Code for Nikai televisions
https://www.eliztech.com/remotes/codelists/nikai-tv-codes
We have no idea what universal remote you have!
Google
make model instructions
1helpful
I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
1helpful
Removing the Child lock when remote doesn't work
CHILD LOCK CAN ONLY BE REMOVED IF REMOTE IS NOT WORKING, OPEN YOUR TV AND CHECK FOR 8 PIN INTERGRATED IC..24C04..ANY NUMBERS LIKLY TO BE FOUND AND REPALCE WITH THE SAME NUMBER, IT WILL WORK
Child lock on on Mikomi 15ldc250, got no RC
mikomi 15ldc250 child lock on but cant find remote control, how do i turn tv on?
2answers
Tv stuck on lock , model is SVLT150 SANSUI 15'' TV. I dont have the remote controller
Hi
Did you mean child lock? if childlock you need a remote control to open this tv..
Thanks!
1helpful
3answers
I have the child lock on and the remote control is broken. How can I turn the tv on without the remote control
The power button on the TV doesn't work because of the child lock?
I went over the copy of your manual for your TV. It must be the child lock timer problem.
I would try leaving the TV unplugged for 30 mins and see if that reset the TV and releases the lock.
If it doesn't work, the remote needs to be replaced. A universal remotes aren't really universal when you need to use special buttons. The remote made for the TV is the best.
If your TV is the model 47PFL7403D, here's the cheapest place to buy a replacement.
http://www.philips.newremotecontrol.com/catalog_item.php?catnum=313922852812
2answers
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
4helpful
2answers
Magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
