SOURCE: KitchenAid oven shut down during self-cleaning
If you are still under warranty, and have "lemon laws"... repaired three times in the warranty period for the same problem... they have to replace the stove. We all need to get Kitchenaid to start replacing these ranges over and over, maybe then they will address the issue. Clean, baby clean... you paid extra for a self clean oven, hold Kitchenaid accountable!
SOURCE: Self Cleaning ShutDOWN HELP
I had the same issue.
Was self cleaning the oven and everything blew.
Part was $45 delivered. Came with two.
Evidently there are 2 thermo discs on the oven. One is located below the door. The one in the back trips most frequently because the units generate so much heat and are generally close to a wall with no room for the heat to escape.
There are two little flanges to take off, then a cross connector. Then the back panel. About 18screws. From there the thermo disc is in the upper middle of the back of the oven. 2 screws hold it in. It is part 830802. I replaced with a 130degree thermo 9759242 . Hope it helps.
I had a part ordered but did not know how to swap it out.
I ordered a therm disc kit from parts-direct.
I read this blog right before the tech called to come over. Saved $65 as a result of the cancelled call.
Better yet, my wife claimed I was playing on the internet. Proved her wrong.
Two victories in one day.
Thank fixya for both.
SOURCE: oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
