20 Most Recent KitchenAid KGRA806PSS Gas Kitchen Range Questions & Answers
not likely this is a common problem it is a thermostat and is located in back panel of stove around 50.00 part
KitchenAid... | Answered on Nov 28, 2016
not good
have you clean it or split something at some time
the igniters can be inspected
wait till gas clears
user manual page 10 ...start button has a control lock design
does the user manual help
https://www.manualowl.com/m/KitchenAid/KGRA806PSS/Manual/249033?page=12
KitchenAid... | Answered on May 18, 2016
Usually, you open the door and you see 4 or 5 screws that hold the inner and outer skins of the doors together. Remove those and lift the inner skin off. Tighten the handle screws and replace the inner skin.
KitchenAid... | Answered on May 04, 2016
I think there might also be a thermocouple involved that keeps the burner /gas valve open when hot .
KitchenAid... | Answered on Jan 21, 2015
You can find the date of your major home appliances at the following link.
Appliance411 Service How old is my appliance Age finder date of...
KitchenAid... | Answered on Nov 01, 2014
Thermostat at the back/rear might have blown.
Is the oven still working?
Then the door actuator motor may have failed.
KitchenAid... | Answered on Oct 07, 2013
Fire place glass cleaner I hear works great.
Possible too much air entering the burner tube to which the burner is attached.
But there might be some soil on the burner that you are not observing.
Will need model number to follow up.
Or send photo to supplier.
It is also helpful to know the shape of the shaft, eg. D-shape.
Replace spark module, if available.
Remove two screws beloe the panel just above the door. There might also be two screws, one on each side/end of the panel.
Lift panel to loosen. Sometimes grease makes it hard to come lose.
Spark board fails...gas valve coils open.. spark probe failure.. among other possibilities.
I have changed all three in the past and the spark probe still does not light. Never found out why.
KitchenAid KGRA806PSS Gas Kitchen Range Logo
154 questions posted
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
kgrc707lbso
  • Kitchen Ranges
