20 Most Recent
KitchenAid KGST307 Gas Kitchen Range Questions & Answers
KitchenAid KGST307
can you tell me the complete model # off the stove? i will try and find the parts instructions for you.
Kitchenaid Superba - oven stopped and code F2E1 is
F2 E1 is an error code that says the membrane (touch pad assembly) is not connecting to the ERC(Electronic Range Control). Call the warrantee company and give them the model number and serial number of your range and ask them if it still has a parts warrantee on the electronics. If it does, they will have to send their technician out to replace the part or parts and charge you for the labor. Your model may have the membrane and Erc all in one part, so an easy diagnosis, if it is seperate you need to make sure the membrane ribbon connector is plugged tightly into the Erc, plug your range back in, press cancel, and then retest. If it still fails then replace the membrane, test and if it fails again, replace the Erc. Before you tear into this make sure you unplug the unit for 30 minutes, plug it back in and test. Sometimes this will reset the Erc and solve your problem. If it doesn't the make sure you unplug the range before doing any repair work. Good Luck, Appliance Specialists
KitchenAid gas stove main burner igniter does not
Hi Cecchung,
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Kind regards, Dik
Maytag Gas Stove Burner Won Light Spark Ignition Switch
Oven wont turn on.
Ours did that and I installed a new igniter. Took the old one out and went to a store that sells them. Installed it myself.
How to level
You asking how to Level the entire range? Most Like refrigerators have adjustable feet that need moving in the direction like a screw. You going to need a Level (duh!), some 2x2 wood, and a fulcrum(something to lift the oven up a little). BE SURE YOU HAVE A) REMOVE UNPLUG POWER B) GET ANOTHER PERSON TO HELP YOU LIFT! While gradually-slowly lifting oven place 2x2 by 6inches long under the oven on both sides. Now you can see the feet and start turning them and they will extend (clockwise usually). Once you do ONLY the front two, repeat the same for the back two. Now you can tell your helper by placing the Level every which way usually three different directions while you adjust the feet till they are level. If this person doesn't "Get It", Be nice and say thank you and find someone who does! (don't Use Your Wife, if married to one)
Random spark from igniter
it sounds like the wire that goes to the stove igniter is shorting out when you are using the oven.
