SOURCE: Kenmore HE2 Plus Error Code: F-20
You probably have this solved by now but for others who read this as I did.............
F-20 means
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Hope this helps everyone else as it did me, thanks
SOURCE: I need the repair manual for the Kenmore HE2 Plus washer
The model number for the Kenmore HE2t front load washing machine is 11047571600. If you go to the Sears site for manuals and enter than number you can get the manual on line.
Hope that helps.
SOURCE: kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding
2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever.
3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
SOURCE: Kenmore HE2 front load washer. All cycle lights flashing plus spin and clothes clean lights on.
I'm sure this is probably too late, but hopefully it will help some else. I just had the same problem. First, unplug the power. Then take the lower front panel off and grabbed a bucket. Place the bucket under the large "plug" on your right. This is the drain. Slowly unscrew the drain plug, Hold your nose as it will probably smell. Allow the water and such to drain into the bucket. When you see the blob of wet lint drop into the bucket you will know why the machine refused to work. Make sure you clean the drain plug and screw it back in tightly. Put the lower panel back on and reconnect the power. I hope this resolves your issue.
SOURCE: My Kenmore HE2 Plus Front Load Washer won't drain?
remove front panel at bottom, get a bucket & clean pump out
