SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
SOURCE: LAVAMAT 74600
Just a bit more on replacing the "coalbrushes" - I generally would call them motor brushes:
I have read a solution on this site which was to replace the motor - I was quoted £199 for a new motor and bought new brushes for just £20.15p, which fixed the problem!
Hope this helps!
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
