Hi Guys, We have a AEG Electrolux L14510 VI washer. The power is on ( orange on/off light is fine)...
(More)
Hi Guys, We have a AEG Electrolux L14510 VI washer. The power is on ( orange on/off light is fine) but the LCD display does not come up. We have pressed every button, changed the dial to all wash modes, even replaced the fuse..any help. Prod number 914510922/00
Cheers]
Keith
I have purchased a new door catch for my W1450, but can not figure out how the springs fit.
Is...
(More)
Is there a manual somewere that will show me?
Thanks,
Rick
first indication - alaem on door sounding i drained all water out using drain tube put onto cold...
(More)
first indication - alaem on door sounding i drained all water out using drain tube put onto cold water and it started to work again then stopped half way through the only thing that seems to work is the door lock? any help appreciated
The machine bleeps when a load of towels are being spun. The water stays in the drum. If I blow into...
(More)
The machine bleeps when a load of towels are being spun. The water stays in the drum. If I blow into the small drain pump hose at the front of the machine the pump will start draining the drum. Another way is to open the pipe and let it drain into a bowl whilst it is trying to drain. It appears there is a vacuum that is stopping the water from draining as the pump sounds as it pumping air. This only happens when towels are in the drum. I have moved the outlet pipe to different positions but this does not make any difference so it appears to be a problem between the drum and drain pump.
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a...
written by jsrock516
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows...
This advice is for Kenmore Elite and Whirlpool Duet Front Loading washing machines displaying the "F22" error code. This is an indication of...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the ?F02? error code. ?F02? is a Long Drain error. If the drain...
This advice is for Kenmore & Whirlpool TOP LOADING DIRECT DRIVE type washing machines. This is NOT for older models equipped with a wig-wag...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the ?F21? error code. ?F21? is a Long Drain error. If the drain...
Welcome to Action Appliance Repair. We have bee... Read More
Welcome to Action Appliance Repair. We have been serving the greater Hartford and Springfield area for over 40 years. We are dedicated to working around your busy schedule. Please call now to receive the $25.00 discount coupon available. We are family owned since 1961. Call now for your free ph
Washer and Dryer repair specialists.
Why hire som... Read More
Why hire someone else to fix your appliance when you can do it yourself? And we can help!
Download a step by step tutorial loaded with pics at www.shop.washermd.com
Our focus will always be to provide top-notch qua... Read More
Our focus will always be to provide top-notch quality service and customer satisfaction of repair services to our customers and partners on Warranty/non-Warranty Dimplex heaters, TV & Electronics, HVAC, Electricity, Home & Industrial Appliances, Sports & Exercise Equipment, Treadmills, Spas & Saunas, Office & Computer Peripherals.
