Washing Machines Logo
Question about Zanussi Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Washer stopping half way with red light flashing on start button wont drain or rinse unless put on that programme, also water is being called at start of programme but is not entering the drawer to swill out detergent into machine, please can you help?
Dado
    Master:
  • Zanussi Master
  • 511 Answers
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Posted on Jan 03, 2015
5 Related Answers
Anonymous
SOURCE: Washer will not Spin during SPIN CYCLES
IT IS THE DOOR LOCK ASSEMBLY, COST AROUND $50.00 WHICH IS FAR BETTER THAN $300.00, WHAT A SERVICE REPAIR PERSON WILL CHARGE YOU. YEA IT'S THE CRAZIEST THING IMAGINABLE, THE DOOR LOCK ASSEMBLY BEING THE CAUSE FOR IT TO NOT SPIN ALL THE WATER OUT. I FIXED MINE MYSELF, HAD TO TAKE IT ALL APART VERY CAREFULLY, BUT I SAVED MYSELF $250.00. YOU CAN GET THE PART ONLINE OR GO TO NEAREST APPLIANCE PARTS STORE IN YOUR CITY. ASK FOR DOOR LOCK ASSEMBLY. THEY WILL KNOW EXACTLY WHAT YOU'RE TALKING ABOUT BECAUSE IT IS A VERY COMMON, I REPEAT VERY COMMON PROBLEM WITH THIS BRAND OF WASHING MACHINE.
Posted on Aug 12, 2008
Anonymous
SOURCE: will not drain after the wash cycle, will not enter the rinse cycle
It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
Posted on Aug 31, 2008
Anonymous
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
Anonymous
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
Why does it smell?
CAUSES MAY BE:poor quality detergents, not using the recommended quantities, or only using colour-friendly detergents or liquid detergent which contain no bleach allowing bacteria to thrive can seriously rot a washing machine inside.
SOLUTION:you can fix that by putting half a cup of white (distilled) vinegar inside an empty machine and put it on a boil wash. Note that because the first bit of water goes into the sump hose and is sealed off, I recommend that you wait until the washing machine has been filling for about 15 seconds before pouring the vinegar into the soap drawer where water is running in to let it wash down into the machine. I've had reports back from people that this does actually work
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
Where would I find a replacement detergent drawer for a Zanussi 1055W washer/dryer?
http://www.ebay.co.uk/itm/Zanussi-Washing-Machine-Washer-Dryer-WDA1055W-Soap-Tablet-Detergent-Drawer/162547763876?hash=item25d89a0aa4:g:fsAAAOSwuxFYzP3t
User manual for zanussi washing machine ZWG 7160 P
how do i replace washing machine drain hose on zanussi zwg 7160p
Water coming out of detergent drawer on drain cycle
possible its not draining fast enough due to a blockage clean out the filter on bottom left.
Zanussi iz 161
Hi there!
Congrats on the twins! Getting any sleep yet?
I think the problem is to do with the water pressure sensor, or hoses inside the machine.
This sensor determines when there is enough water in the machine, and turns the valve off.
If you are competent to have a look, then continue -
Isolate supply and turn off water connections -
Remove the lid by removing screws at the rear, and slide back.
Check the air hoses that are near the drawer area. It is not uncommon for one to just come loose, or rip.
Reassemble and turn on to check opperation.
If this assists you, please spare a moment to rate as Fixya! as I would apreciate it. Thank you.
If not, contact me again for further items to check.
1helpful
Leaking water
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine. Also use only detergent for 'front loading machines'.
The fabric softener doesn't go in...
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Top Zanussi Washing Machines Experts
Marvin
Marvin
sheakhly
Level 1 Expert
mark warfield
mark warfield
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
