Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
SOURCE: 4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
SOURCE: My Laserjet 4200 dtn with Envelope Feeder is
Sounds like you have a bad fuser. Are you using refilled 3rd party toner or genuine HP toner?
measure the distance from first instance of the repeated image to the next instance on same page. This will identify if the image is stuck on a fuser roller or the toner's photoconductive drum.
each roller in a printer has a different circumference and repetitive images can be diagnosed this way.
provide the measurements as close as possible in fractions of inches or cm's.
Thank you,
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools
, click Letters and Mailings and then click Envelopes and Labels
2) Type the Delivery and Return address information.
3) Click Options
4) On the Envelope Options
tab, set the following options:-
5) Select the Printing Options
tab and verify that the following settings are selected:
6) Click OK
and then click Print
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
Have a nice day...don't forget to rate the solution.
SOURCE: HP Laserjet 4200 with optional
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
