Led is flashing 8 time amber and in book it stays watchdog timeout reboot,what does this mean and how can i fix this,it is a new system and installation and can only get to about 130-140m before loosing the bottom
OK, i can elp you but before that haver you tried rebooting because then, i would be able to teach you an how to digitize the xf region battery as well as the system compartments
? I wounder what color is your lamp - red or yellow (amber) and just so you know most parts stores now days can tell what a code is with out charging a dime to you.
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
I have the same problem. This is the second bulb in 6 months. The first one lasted 13 months. The bulb explodes inside and makes a loud snap noise, like an arc. The repair guy said it was the ballast along with the bulb. Good luck
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash typeReady LED (Green)Manual feed LED (Amber)Error LED (Amber)Meaning
Flash 1 -- slow blink
X
The printer is processing data when printing has been suspended.
X
The image drum required changing or toner is low.
Flash 2 -- blink
X
The printer is receiving and processing data during printing or the printer is resetting itself.
X
The printer is requesting manual paper feed.
X
There is a printing error, problem with paper or a cover open.
X
X
X
There is a minor error with the printer.
Flash 3 -- rapid blink
X
X
X
There is a major error with the printer.
