toshiba 50hm66 that flashes the yellow lamp light three times. It is supposed to do that before...
(More)
toshiba 50hm66 that flashes the yellow lamp light three times. It is supposed to do that before going into standby mode. I tried to reset it while this was happening. There was a click a pause then another click ,but nothing else happens
my tv will come on with sound and no picture. it keeps shutting down and the green light keeps...
(More)
my tv will come on with sound and no picture. it keeps shutting down and the green light keeps flashing 15 times between shut-downs. it does come back on immediatly with sound.
i have the same problem took it in to get fixed and they cant find a problem with it even put in a...
(More)
i have the same problem took it in to get fixed and they cant find a problem with it even put in a new lamp
Comes on dim then fades to black in about 15 seconds then trys to restart but won't, has brand new...
(More)
Comes on dim then fades to black in about 15 seconds then trys to restart but won't, has brand new bulb.
the light blinks 1-1-1 blank 1-1-1 blank and so on i was told it was stuck in quick start mode. can...
(More)
the light blinks 1-1-1 blank 1-1-1 blank and so on i was told it was stuck in quick start mode. can anybody help please???????
I have a 50" DLP Toshiba 50HM66/SAM, I have a small crack from an accidental hockey ball...
(More)
I have a 50" DLP Toshiba 50HM66/SAM, I have a small crack from an accidental hockey ball hitting it, I am looking to replace the front anti-glare screen. Does anyone know where I can get this piece from?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
