Raymarine St 4000 Wheel Drive E12093 Logo
Question about Raymarine St 4000 Wheel Drive E12093
Service Manual for Autohelm's st4000 Wheel Drive Autopilot
Is it possible to find a free copy of the Service Manual for Autohelm's st4000 Wheel Drive Autopilot?
Posted by tucan1 on
Anonymous
    New Friend:
Hi, If you are looking for Autohelm service manuals you may find them at http://sdmarine.online.fr/Service%20Manuals/Autopilot%20Systems/
Posted on Mar 05, 2011
Anonymous
  • 38 Answers
Yes check at google on the internet
Posted on Jun 21, 2010
Where do I find the parts number for the clutch lever and pin for ST4000 to order from a marine store?
The clutch lever for the black wheel unit st4000 has Autohelm reference N011,see at Westmarine,is sparepart is available
I have an older ST4000 AutoPilot and this summer the drive motor doesn't seem to function. How do I disconnect the wires to determine if I have power coming from the control head and what voltage show I...
You can check it in 2 places:
1) the back of the control head
2) the motor itself. The wire plugs into the motor or the shaft coming off the wheel portion.
You should have approx. 12 VDC coming from the control head to the motor.
4helpful
2answers
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
My st4000 mkII shuts off from auto mode whhen i engage the clutch lever and the wheel turns for a second. the screen goes blank and just displays "st4000" . voltage is fine and all wires are connected....
CHECK THE POWER SUPPLY WIRING ,If it worked before ,could be corrosion or lose wire connection,or terminal bad crimped,or terminal loose inserted.
If it is new installation ,power wires could be undersized,or battery discharged .
Normally autopilot shuts off from auto and restarts when power supply voltage drops under the reset voltage ,when the wheel turns ,the motor current increase and the power voltage drops when the power supply wires are not OK.
1helpful
I HAVE A 1997 AUTOHELM ST4000 AUTOPILOT AND THE
GLUE THE SMALL POSTS EXACTLY IN PLACE AS THEY BROKE OFF ,DRILL A HOLE VERTICALLY THROUGH THE POSTS ,SAME SIZE AS HOLE IN THE SS WHASHER, (HOLE OF THE SCREWS)ALL THE WAY THROUGH THE BACKPLATE ,INSTALL A STAILLESS SCREW WITH HEAD ON THE REAR OF THE BACKPLATE AND NUT ON THE WASHER SIDE TRIM TO EXACT LENGHT USE LOCKTITE FOR NUT.
1helpful
ST4000 autohelm
The clutch lever shearpin is on the outside through the body of the clutch lever
Top Raymarine Boating Experts
Colin Stickland
Colin Stickland
Mike
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
