20 Most Recent IBM eServer xSeries 346 8840 (884022U) Questions & Answers
Do you get the 12v side also?
IBM eServer... | Answered on May 08, 2019
I need to know where the red light is? email wwrics@verizon.net and what the server is doing as to booting or running. I am a hardware tech and can assit with hardware issues. wwrics
IBM eServer... | Answered on Jul 31, 2012
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
IBM eServer... | Answered on Apr 05, 2010
1 power supply is out...
2 motherboard is out....
IBM eServer... | Answered on Dec 14, 2009
Assuming that this is resolved as it appears to be an old, time-sensitive issue.
Although I would say that what you're asking would have been a design choice on IBM's part. The BMC would dictate fan curve and if one of the fans is not spinning at the minimal RPM - as specified in that fan curve - then it would obviously shut the system down to protect it from heat damage.
You may be able to adjust this using various commands in the BMC but I am not familiar with IBM's hardware. (Which is likely different in the same way that Dell's iDRAC differs from HP's iLO, etc.)
I'd say it's unlikely either way.
IBM xSeries... | Answered on Jun 13, 2015
bad net Connection or netcard
IBM xSeries... | Answered on Aug 18, 2014
I would check the firmware/bios as these had a known issue.
Check with IBM for the latest firmware and BIOS.
Update me if this does not resolve the problem.
IBM xSeries... | Answered on May 13, 2014
Server is model is not mentioned.
You can clear logs by this way..
1: Get into BIOS and there you could see server logs. Clear those logs
2: Get into IMM and you can find logs there. Clear those logs (This is applicable to servers with IMM and Uefi firmwares)
3: Get into BIOS and find out IPMI logs. Its under Advanced settings.
Clear those (This is applicable for older x series machines with BIOS firmwares)
Thanks
IBM xSeries... | Answered on Apr 10, 2014
Guide events have changed the identification protocol and a refreshment of the input data to the Event ID structure will fix the problem. This must be done within 24 hours of the last formal event or else the system will crash and no longer be salvable.
IBM xSeries... | Answered on Jan 28, 2014
go into bios and change start up type from uefi to legacy if you don't have the option update the bios
IBM xSeries... | Answered on Jan 07, 2014
Well it usally means the fan is bad it may work and keep your CPU cool but it can still send the code just replace the fan
IBM xSeries... | Answered on Oct 25, 2013
you need to install a "server OS" either (server 2000 or 2003, 2008)
windows xp will not work on the sever machine
IBM xSeries... | Answered on May 02, 2013
Depending on version you have the should numerous boot options, like power off / on, ctrl alt del, and so on. You may also require admin rights. Some accounts only have read only.
IBM xSeries... | Answered on Jan 21, 2013
Update bios, reinstall Chipset driver else use external USB PCI card
IBM xSeries... | Answered on Apr 06, 2012
IBM eServer xSeries 346 8840 (884022U) Logo
11 questions posted
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
xSeries IBM
  • xSeries IBM
Most Popular Question
its not booting leds vrm nmi amber color
  • Computers & Internet
