Make sure that you have the correct audio drivers for the make of motherboard. Go to start, run, then type in dxdiag and press enter. This will open a box where you can go to the 'sound' tab and check the sound configuration. Also, on the right of the taskbar, right click the speaker icon and open volume controls. Make sure all of that is set up correctly. If you still get nothing, go to control panel/system/hardware/device manager and check that it shows your sound controller under sound and game controllers. If it doesn't, you might need to turn off, clear the CMOS memory, start up, and re-install drivers. Good Luck! :)
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
using this link you will be able select your drivers (appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio volume advanced speakers make sure you have selected the
hope this helps
Realtek AC
