Question about Intel Motherboard
Hello here is some youtube video that shows how to connect the front panel connectors:
http://www.youtube.com/results?search_query=build+a+pc+front+panel&oq=build+a+pc+front+panel&gs_l=youtube.12...21605.28118.0.31454.12.11.0.1.1.0.65.529.11.11.0...0.0...1ac.1.XVeb42AVbpQ
This is basicly the same for all msi mainboards:
Good luck
Posted on Dec 09, 2012
SOURCE: How to connect Power LED, Power SW, Power Reset and HDD LED
Here is the manual for that motherboard: ftp://download.intel.com/support/motherboards/desktop/d815eea/A1696401.pdf
page 14 should be what you are looking for.
Posted on Jan 28, 2009
SOURCE: How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
Posted on Aug 20, 2008
SOURCE: Front Panel Connector
There should be a Front panel block on the motherboard
you should connect to it like this
Posted on Nov 15, 2007
SOURCE: Gigabyte GA-8INXP Motherboard Problem- front connector pins
try to look on the wires of the casing. you can see the names on it of each wires.
PWR LED are the light on the case of your cpu(steady light)
+HD- is led light of hardisk.
+PW- is the switch of you power button.
+RES- is the switch of your reset button.
+SPEAK- speaker of your computer that is located on the front of your casing. it has a hole on it so that you just can insert a speaker with a rc jack aside from the rear casing of your speaker.
CHARCOIS
Posted on Sep 19, 2008
