Hi! May I ask If you feel the motor of the fridge humming or something? Is the light inside working or it is completely dead? Hope you can tell me more. Thanks!
It sounds like you are definatly having A voltage problem. It also sounds
like it affecting the whole house. This could be a transformer issue a
power company supply issue or a fuse/breaker issue. I am an electrician
and have been for 13 yrs. That being said call a professional. Without
being there and seing what your looking at it is nearly impossible to
safely walk you through checking your voltage. 120/240 kills more people
every year than any other voltage and thats what is in your home.
Please trust me if you don't know let it be call a electrician and play
it safe I live in pa so I am not trying to get work just want you to be
safe.
refrigerators come in three types: with the freezer on the top,
with the freezer on the bottom, and with the freezer and refrigerator
next to each other, also called a "side-by-side." When Plus
refrigerator won't get or stay cold, troubleshoot it at home before
calling for service to save time and money. Always use and adjust your
refrigerator, according to manufacturer's instructions to prevent
voiding your warranty or causing further damage.
Preliminary Checks
Check the air vents on the refrigerator. These are
located at the bottom and normally blow out warm air. If the air vents
are blocked or clogged with hair and dust, the refrigerator won't run
efficiently and cool food properly. Unblock the vents or clean them with
a brush or cloth to remove the hair and dust.
Check to make
sure the refrigerator and freezer doors are both completely closed. Keep
the doors closed for a while. The temperature
After
all your home troubleshooting efforts have failed, call Maytag or the
retailer who sold you the refrigerator for service options. Have your
receipt and warranty paperwork handy.
From your description , the main control board shorted . This is the electronic board behind the refrig , behind the small 8 X 10 panel . All individual parts , fans , display board , dispensor board etc , are wired directly to the control board . It is easily replaceable with 6-8 sets of plugins . WR55X10942 is the part number .
we lost power last week and my fridge/freezer will not stay cold...the light comes on, the fan blows, the fridge makes the same noises ..like when it worked properly
