Re: How do i change language back to english from spanish
Taking a guess at this but push the menu button once.. then the down arrow 5 or 6 times. and select it should bring you into the language menu and just click enter/ok. This should change it back to english.
AppleOct 28, 2015 - Learn how to change the language setting on your iPhone, iPad, or iPod touch if it's incorrect or if you've accidentally changed the language to ...
discussions.apple.com > Support > Apple Support Communities
AppleSep 13, 2011 - The autocorrect and all of the keyboard buttons have Spanish ... I try changing it back to "English" or even "British English", and instead it shows ...
? 1:03
https://www.youtube.com/watch?v=vKNvMzl9ShA
Mar 16, 2014 - Uploaded by Adam Bednarz
These steps will get you into the language settings if you do not know the language selected. ... Fake vs. Real ...
You need to use the remote to go to the setup menu and set the language to English, or if you are in the USA set it to US English, which is different from English.
solution you can change your Spanish to English language. at first you in menu to language setting and change your language. Thank you Send report :[email protected]
Start > Control Panel > Clock, Language, and Region > Regional and Language Options.
Once in the Regional and Language Options, click the Keyboards and Languages
tab. If you see a drop down list of languages, see if it is set to
English. If not, set to English. However, if you do not have this list
there, you may need to install it.
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
Login to your gmail account. On the right side you should see your e-mail address up top next to that is "Settings" (or whatever in spanish. Select that and on the first tab the first thing it shows you is language. Click the dropdown and change back to english.
