Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on May 29, 2010
Color is horrible basically black and white - Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on May 29, 2010
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2823038
Points
26282
Ur tv colors wheel is dead,colors wheel is the problems,must be change.When the tv picture are black&white,colors fade in & out,loud squiling and motor noises.All these problems,indicate the colors wheel it dead,require changing.Hire a tv tech.for this job,because the colors wheel replacement require to take out alots of machanical's parts even able to get to the colors wheel to replace it.
Testimonial: "I'll have to call a tv tech. Thanks"
If black ink is out, will copy in color possible from pc? Also how do I reset this printer?
Dear
Since the model is not found, its difficult to say. however in most cases the subtractive colors are used ie cyan,magenta and yellow. with mixing these white is produced but in case of basic color used ie. red,green and yellow, on mixing these black color is produced. Mostly cyan, magenta and yellow is used hence you can not produce black color so the a complete color print not possible.
Thanks.
Konka 32 lcd tv kl32bs22u
RCA ouputs :
locate those colors
RED
YELLOW
WHITE
in a row usually label AUDIO/VIDEO
2answers
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Color is terible and can fix it
This DLP tv have a colors wheel.Ur tv colors wheel is dead.When u have black & white picture,colors fade in and out.The tv make loud squiling or loud motor noises.All these problems are related to the colors wheel.Hire a tv repair Tech. for this job,because the colors wheel,require take out alots of machanical's parts out even before to get to the colors wheel to replaced it.
Hello sir i am sasi from india pls tel me international color codes electrical wiring
Well colors can vary, but basically bare copper or green are grounds, white is the neutral wire (but it is powered in a switch loop, and when used in a switch loop it is taped with a piece of electrical tape to show it is powered). Black, red, blue, brown, and pretty much any other color except green and white can be a power wire (black red and blue are the most common colors used).
White Out/Washed out
well if you can still see its okay but if it goes haywire and freezes u have got yourself a problem, my friend
Add color to black and white photos
hi, this is arul ,
just mail me ,
my id is arul_eabi @yahoo.com ,sake careo that i can slove ur problem,
because iam in office now
bye take care
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Projector only displays Black and White / No color images.
The problem is the color wheel. It may have broken or motor stopped on clear. Either way the image will remain unchanged just without color. It will need to be sent in for service. Not an unusual problem for BENQ. I have had 3 that have come apart after making a loud whirring sound. Good luck getting someone with BENQ to help they are horrible when it comes to service. Buyers beware!!!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
