I see a crack in screen on top right but it should still display (however touch won't work). Look at the ribbon connector which connects display to the phone PCB, it should be firmly secure in its connector. Also try cleaning the PCB with alcohol, if still doesn't work then either you need a new LCD or some chip is blown.
You might try removing the battery for a minute or two to reset the camera. You may lose any special settings in the process. After reinstalling the battery, try turning the power on and off again.
Your coby is not charging anymore..The battery probably needs to be replaced with a new one..Please check your connection when you charge it..There should be an icon that shows your battery is charging. If it does so that means your coby is charging but your battery cant store the energy anymore.
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
