I have removed the door catch from the door and nothing looks broken.
When looking at the catch on the body of the machine i can see a small metal plate (I assume that this is the magnetic catch to keep the door locked when in use). Could this be at fault?
If i need to remove the front panel to sort this can you please advise me of where the screws are to do this.
Many thanks
SOURCE: remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
SOURCE: Bosch WFF2001 can I use it cold fill only
Sure it will work but both fill hoses have to be hooked up or you have to buy a hose bib cap to place on the hot side to keep the water from comming out the other side.
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
You first of all need to
check the pump filter. This is
located at the bottom front right of washer. Look for a drop down flap or cover, once
located, unscrew filter anti-clockwise to remove and clean. Of course be prepared for a lot of water and
junk. The pump itself is directly behind
the filter housing, check there to see if anything is stuck in the plastic blades. It should turn freely. Your washer door will not open if there is
water in the washer, just some kind of precaution, so don't force the door.
Pl click if helped..
