If you use a multi-system TV, you can play discs recorded on both PAL and NTSC systems by setting the VIDEO OUT SELECT (NTSC/PAL) switch appropriately. However, note that you must change the switch position while the unit power is off with the DVD removed (on standby). Otherwise, the changed setting is not effective.
If you do not have a multi-system TV, note that the JVC XVS332 does not convert PAL to NTSC, it just plays both; therefore you will loose color information & see only black and white with PAL discs on an NTSC TV.
I hope that helps.
_______________________________________
JVC XV-S332 DVD Manual
Download
Yes this helps. Thank you. Problem solved.
