MACHINE JUST WON'T DO ANYTHING WHILE CODE IS UP
SOURCE: F35 failure code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(*&^
SOURCE: what does code f35 mean
I found this for you:
"F35" Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
SOURCE: f35
Code 35 if a pressure switch problem. If you remove the top panel the switch is located at the back right corner if looking from front to back. It a brown color usually. Check the hose from the tub to the switch and the wire connections if they are ok then replace the switch. Make sure to unplug the machine before removing the top
SOURCE: what does the code F35
The F35
indicates that the main control board detects a problem with the analog
pressure sensor (water level pressure switch) in the washer. This
component senses and controls water level in the washer. This failure
could
be caused by a pinched or broken air hose between the air trap at the
bottom of the washer tub and the analog pressure sensor. It can also be
caused by a clogged air trap or a failed analog pressure sensor. If you
are able to unplug the washer and pull off the top panel, you can
check for the probable cause of this failure.
To remove the top
panel,
remove the screws on the very back of the panel that secure it to the
washer
cabinet. Pull the top panel back slightly and then and off of the
washer. It is on the side wall just behind the expansion control board.
You
can check the air pressure hose connection and the wire harness
connection on this component.
This component costs around
$99.This information was based on the general description of the washer
model that you provided (Kenmore Elite front load washer). There are
several different models of this washer.
