Fault code F35 on my washer what does it mean?
Posted by Sharon Thurman on
Andrew Taylor
    Top Expert:
  • Washing Mach... Master
  • 31,588 Answers
The F35 error code indicates an analog pressure sensor error. ... This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem.Jun 3, 2011
SOLVED: F35 error code appears during cycle - Kenmore Elite HE3 ...
https://www.ifixit.com/Answers/View/54204/F35+error+code+appears+during+cycle
See this link and watch the videos
Fault code F35 washer Google Search
Posted on Jul 31, 2018
What does F35 code mean and what to do?
  • Run an empty cycle without using any detergent. Often the fault code displays when too much detergent is used and the detergent sits in the drainage system. A cycle without any detergent is often enough to clear out the buildup.
  • 2 Pull the drain hose out of the standpipe mounted to the wall behind the washing machine. Complete a visual inspection of the hose for any clogs. If you see any, remove the screw that holds the hose clamp onto the discharge pump and then force water through the drain hose with pressurized water from a garden hose. Reattach the hose and then run an empty cycle to see if the code goes away.
  • Read more : http://www.ehow.com/how_11368049_fix-whirlpool-washer-f35-code-alert.html
    Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
    I keep getting the error message F35. Can you tell me what that means?
    The Central Control Unit detected a fault in the analog pressure switch but it could also indicate a draining problem. Check the link below to see what you can try to address the problem.
    Troubleshooting Error Code F35 on Kenmore Elite and Whirlpool Duet Washers
    Nov 03, 2010 | Washing Machines
    F35 failure code
    F35 is a water level error.
    The water level switch (pressure switch) has malfunctioned.
    If you remove the top panel, three screws in the back, you will have access to the pressure switch.
    With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
    If the fault codes return after doing this, you will likely need to replace the pressure switch.
    Also - please be sure to use He soap.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(*&^
    Jul 16, 2010 | Kenmore Elite 45986 Front Load Washer
    My Kenmore Elite HE 5T Steam Front Loading Washer keeps flashing the code F35. What does this mean? It is not in the manual.
    May 02, 2010 | Kenmore Elite 45986 Front Load Washer
    Code F35 on Kenmore Elite HE5t front loader washer.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
    Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
    Fault code F35 what is this?
    F35 means: ANALOG PRESSURE SENSOR FAILURE
    If this failure is displayed, there is any malfunction detected by the Electronic Board.
    1. Check if pressure hose is fixed correctly.
    2. Check if the airtrap is not blocked.
    3. Check if the drain hose is not blocked
    Dec 23, 2009 | Kenmore 44102 Front Load Washer
    Just bought Kenmore elite washer and upon initial wash I got F35 blinking code and the washer stop working. What does this mean?
    Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
    Sears Kenmore HE3 Error Code F35
    Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    146 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
