Lexmark C543dn 26B0000 Workgroup Up to 21 ppm 1200 x 1200 dpi Color Laser Printer Logo
Posted on Apr 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reads 107.08 error
Reads 107.08 error printer head how do you fix
  • Official Brand Answer 3,344 Answers
  • Posted on Apr 13, 2010
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923803
Points
5508
Try to reseat the printhead cable at the back of the printer. Here are the steps:
1.Turn Off the printer and unplug the power cable from the wall outlet.
2. Open the back metal plate of the printer using a philips screw Driver.
3. Once the Metal plate is off from the printer, you will see a flat white cable or a ribbon cable at the top center of the printer circuit board. The cable is wrap with a black metal piece.
4. Unplug the cable using both hands and then put it back and make sure that it is properly seated.
5.Put the cover back into the printer, plug the printer into the wall and turn it ON. If the error still persist, replace the system board and the printhead assembly of the printer.
Hope this helps. If you need more assistance, place a comment so I can get back to this. Thanks.
Code U051, change the cartridge color and it is the same.
The error U051 / U052 indicates that a communication issue with the print head. This can be caused either by the print head not being installed or print head not working properly. The issue U051/U052 canon printer can be fixed easily.
·Reset the print head
·Restart the printer
·Check ink cartridge
Read continue the steps to fix the U051/U052 error code in canon printer.
2answers
How to Fix Error Code: B200 on Canon Printers?
The B200 Canon printer error can be caused if you have a faulty or improper printer print head. You can easily fix the canon B200 with simple methods.
·Clean the printer print head
·Check the ink cartridges
·Reset the printer
Read continue the steps to fix the B200 canon printer error. Also find the more canon printer error codes and their solutions.
Hi, ive got an ET-4500 and just received the following error code 0xF1, ive turned it on and off twice but still have the error
The Epson printer error Code 0xf1 is due to a corrupt registry entry on your PC (Computer). When this error occurred, then the print head is not able to move.
Troubleshooting methods to fix Epson Printer error code 0xf1
·Reset the printer settings
·Set Epson printer as a default one
·Update Epson printer drivers
·Clear paper jam
Read the following steps to
fix the Epson printer error code 0xf1
Shows print unable 4F
The LCD displays an error code with problem with Printhead. To fix Brother Printer Error Code 4f go through eh 2-3minutes read of blog either or connect o right experts for assistance. The causes to this error is connection failure of the carriage-head flat cable or head flat, Print head defective, Power supply PCB defective, Main PCB defective. Looks of the causes and move ahead with the issues. Brother to help you settle on your printer obtaining choice, read the Brother Printer Error Code 4f surveys and evaluations. Impart following Model Brother Printer such as:
    ·Brother multifunction printers
    ·Shading laser printers
    ·inkjet Printers When you are searching a Brother Printer answer for a home used or home office, little or medium business, or substantial business or workgroup, the impartial Brother Printer tech experts direct you towards the right printer solution. Connect to Brother Printer Support Number for proper and one to one assistance with experts.
Brother Printer Technical Support Blog News 1 800 213 8289
2answers
Error B200
Canon Printer Error B200 means a faulty print head. A print head is a part that divides the ink from the cartridges on the paper, indicating it's one of the several important features of the entire printer. Print heads are known to be problematic, particularly on cheaper printers.
6 steps to Fix Canon Printer Error B200:-
1. Reset the printer.
2. Remove any obstructions.
3. Clean the printer head.
4. Manually clean the print head.
5. Remove old ink.
6. Re-install the printer drivers.
For Expert Advice check here- Canon Printer Error B200
Epson t60 the two light are blinking
The Epson printer light blinking when you have low or empty ink in tank, Lack of communication between printer and computer, printer print head overheated, fuser not working and more.
Follow the steps to fix Epson printer lights blinking error:
·Fix paper jammed
·Check printer ink cartridge
·Check network connection
Read more steps to fix Epson printer lights blinking error.
Error message reads "unable to
It means that the printer is unable to clean the print head number(s) 46. The print head is located under the ink cartridges. Remove the cartridges, and you should see a plastic piece with a hole in it to put your finger under and snap open. This allows you to see the print heads. The print heads look like a sponge type dabber on top of a plastic case. Grab a hold of the print head and pull it out. Look for ink that has spilled behind it or on any of the brass colored computer connections. use warm water and a lint free cloth to scrub it off. Press the print head sponge with your finger and make sure that ink primes and fills the head then put the printer back together and try a test page. If you stll get the error then you need to contact brother for a print head replacement.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
